No DLNA Device..
    No DLNA Device..
    I'm reloading HS3 because of an odd failure,, on this reload the PI did not appear to make an DLNA device as it did the 1st time.. Any ideas ??
    TIA.
    TIA.
    What do you mean by "reloading HS3"? Did you wipe the DB, in that case the PI will be out of sync because it keeps its own DB. Stop HS, go to the config folder, delete the MediaController.ini file. Start HS again. All devices will be deleted and you will have to add them again.
    Dirk
