Me and my wife are on iOS so Geofency or Btraced seem to be the apps to choose from. Primary use will be to detect when at home and not. I assume both apps together with PHLocation can manage that.
If I understand correctly, with Geofency the fences need to be set on each device and when you enter or exit a fence the app reports to the plugin. With Btraced you set a perimeter in the plugin and the app reports the device's location.
If I have assumed right it would be easier to manage the setup from HS/PHLocation using Btraced, specially if you have several devices. In the same time I guess battery life would be better with Geofency if the app only reports on fence entry/exit.
I would highly appreciate some advice on which app to choose.
