Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion > HAI/OMNI Panel for HS3 Plug-in (rmasonjr)
HAI/OMNI Panel for HS3 Plug-in (rmasonjr) Discussion about Rob Mason's HAI/OMNI Panel Plug-in
Old October 8th, 2017, 07:35 PM
lakemirror's Avatar
lakemirror lakemirror is offline
Seer Deluxe
Panel disconnect after burglar alarm
Had the first instance of panel disconnect in quite a while tonight.
The system was set to armed day and I opened the front door. Didn't hear the warning beeps, and the alarm triggered. Almost immediately got a text message saying the panel had disconnected. The panel reconnected and then disconnected again about 7 minutes later.
Logs emailed.
Tom
Old October 8th, 2017, 08:13 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
OverSeer
Thanks Tom I'll take a look and report back.
Sent from my Galaxy S7 Edge using Tapatalk
61 Z-Wave Nodes, 162 Events, 293 Devices
Plugins: Z-Wave, BLRF, HAI, HSTouch, weatherXML, EasyTrigger
Old October 9th, 2017, 12:39 PM
Pete's Avatar
Pete Pete is offline
OverSeer
@Tom,
It might also be the draw on the panel causing an issue. There is a similar post on the Cocoontech forum today relating to an Elk M1 panel.
Way long time ago here (first time installation) went to an outdoor and indoor sounder(alarm).
They did draw too much amperage. It was suggested to use a relay instead and power the sounders separately.
Rather here went to low amperage sounders and a separate HAI subpanel for the consoles. Well too went to 3 different panel battery backed up power supplies for the adds here. (main panel started at 16 zones, then 32 zones and finally 48 zones).
Automator
Old October 10th, 2017, 09:37 AM
avpman avpman is offline
Seer Plus
Logs emailed.
Tom
How do you setup a text msg to alert that the panel disconnected?
Old October 12th, 2017, 11:48 AM
lakemirror's Avatar
Seer Deluxe
Quote:
Technically it's a email message sent to my carrier's email to text service.
Old October 12th, 2017, 03:20 PM
Seer Plus
I get how to send an email/text. but the only Omni "IF" condition available to me is "OMNI: User Armed/Disarmed." There are no other conditions available for the panel. What am I missing/doing wrong?
Thanks in advance!
Old October 12th, 2017, 06:44 PM
lakemirror's Avatar
Seer Deluxe
Start off with "If a devices value is"
Then select "This device changes and becomes"
Then you will see the list of all devices
HTML code is On
Solar panel disconnect IP addressable Ricky HomeSeer General Discussion Area 8 April 19th, 2011 09:07 PM
RFXCOM Alarm Panel & SC28x Alarm msweb RFXCOM Plug-In (3P) 2 December 2nd, 2008 02:32 PM
Burglar Alarm chrisdutoit_2 HomeSeer General Discussion Area 4 September 28th, 2008 11:34 AM
Any Good Security/Burglar Alarm Scripts heatvent Script & Plug-In Library 0 June 2nd, 2008 10:31 PM
Bass burglar alarm does not respond Rien du Pre General Home Automation Hardware Discussion 3 September 22nd, 2004 11:22 AM
