Setup Weather XML
    Setup Weather XML
    I installed version .374 of HS. I can duplicate what you are describing. I went to the locations page and changed between every one of the possible source providers including NOAA.
    Jeff Farmer
    HS 3, HSPhone
      You can duplicate what I am seeing but then I think you mean you can select all the providers. I am not sure what you mean. Sorry if I misunderstood your post
      Bob
        My apologies. I mistyped can when I meant can't.
        I haven't been able to duplicate what you are running into.
        Try this. Stop then restart weatherxml. Let's see if that clears it.
        Jeff Farmer
        HS 3, HSPhone
          Restarted XML, no go. Removed XML and reinstalled no go. After I removed XML again I see allot of files left on the system so I will go and very carefully remove any Weather XML files and try again.
          Thank You Bob
          PS XML weather was working with no problem until I upgraded through several versions of the HS3 beta. Now at .314
              Update:
              I upgraded to HS3 .376 and I am now able to select my weather station KBLM. I was not able to download the XML file so I closed out and go back into Weather XML.
                Originally posted by ralnet View Post
                Update:
                After you setup the locations you will need to go to the schedules page and set how and when you want the downloads to run.
                Jeff Farmer
                HS 3, HSPhone
                  Thank you Setup complete
                  Bob
