** BLRF is RELEASED **
    #61
    Originally posted by Rotech View Post
    Bob, quick question, will I have to enter each device again, or will there be a conversion tool of some kind?
    I assume you are talking about the security devices. You would have to enter them in again. The addresses will be the same so you can just get a list and then starting adding.
    Cheers,
    Bob
      #62
      BLRF Log with ALL ON & ALL OFF Commands
      Originally posted by Blade View Post
      That log is not very long. You need to leave debug logging on for longer. I only got the HS startup and that was it.
      Turn it on and let it run for a bit. Try and capture an ALL ON and ALL OFF for me if you would for each house code.
      Attach it here zipped
      Here is the BLRF log after some commands. First, I sent commands from the PalmPad. No response from modules. Then I send commands from the HS3 device web page. Modules respond. Then I tried HSPhone. Modules respond. I tried an ALL ON and ALL OFF from the PalmPad. It shows up in the log.
        #63
        Thanks for the log. Ignore the email I just sent you. This will do for now.
        I will have a look as to why the X10 signals are not getting sent.
        Cheers,
        Bob
          #64
          I did not see any ALL ON and ALL OFF in the log. What did you see for those?
          Cheers,
          Bob
            #65
            I saw a reference to ALL OFF in the BLRF log, but I looked again and it was a reference to one of my events on C1 titled All OFF. I press C1 on my PalmPad when I crawl in bed to turn all the lights on Housecode C to OFF. Since RF is not working right now, I wouldn't expect it to be there.
              #66
              When you press C ALL OFF you should get something in BLRF in the log.
              What remote do you use to do this?
              Cheers,
              Bob
                #67
                Can you try build 1.0.9 in the updater and see if the X10 is working.
                If not attach a debug log. Thanks
                Cheers,
                Bob
                  #68
                  OK, deleted the old BLRF file, added the new 1.0.9 plug-in, had to close HS3 and restart to get it going. Still looks like the ACRF is getting the signals to BLRF, but HS3 is not sending them out. I had attached both HS3 and BLRF logs. The last entries in the log are where I manually send an ON and OFF command by clicking the device on the HS3 device screen. That works. The X10 plug-in still hasn't been updated, but I saw a couple of hours ago that Ryan was working on it.
                    #69
                    Send me your email address and we will continue this in email
                    Cheers,
                    Bob
                      #70
                      Here is another BLRF log with an attempt at ALL OFF and ALL ON commands starting at 3:52pm. It looks like to me like ALL OFF is coming through as C1 DIM, and ALL ON is coming through as C2 BRIGHT. But I'm not a programmer, so I don't know what I'm looking at.
                        #71
                        Version 1.0.10 is released in the Updater
                        • Attempt to fix X10 signal not getting to actual devices for control
                        Cheers,
                        Bob
                          #72
                          Blade
                          1.0.10 now works with x10 palmpads and ms13 motion sensors
                          Going to try some ds10's next !
                          Will let you know.....
                          Neil
                          Newmarket Ontario
                            #73
                            Great to hear.
                            Let me know about the DS10s
                            Cheers,
                            Bob
                              #74
                              Blade
                              Sent an email
                              Can't send a .log file ?
                              Neil
                              Newmarket Ontario
                                #75
                                You should be able to attach the log zipped.
                                Cheers,
                                Bob
