Very confused status
    I have attached a recording of the issue please see the zip file for a windows recording step by step of the issue.
    the problem is the image and words of the status of the lock do not match and get confused with each click
    I will have to check this out tonight at home since it is blocked here at work
    Can you also let me know the lock model you have
    Cheers,
    Bob
      I see it is getting confused
      Capture me a debug log of this happening in the plugin and attach the BLLock-Detailed.log file zipped
      It is located in the HS3 root folder
      Cheers,
      Bob
        will get log asap it is schlage fe599
          here is the log file
          log file attached
            I see the plugin getting a 0 for unlocked and 255 for locked
            This is strange - I will have to investigate this more
            Is it possible the page needs to be refreshed? It does not refresh automatically
            Cheers,
            Bob
              more issues
              I had not been able to get BLlock working any longer you put out an update to ver 2.0.73.0 and after I installed it bllock no longer sees my schlage locks si I cannot see if it is a page refresh issue
              BTW I deleted anything with bllock from the hs3 directory tree and restarted hs3 and reinstalled bllock and still no luck seeing the locks
              THANX
              MITCH
                here is the current log
                the locks are at 145 and 146
                  It is not recognizing your locks
                  Can you try running the script in this thread
                  https://forums.homeseer.com/showthread.php?t=161081
                  Attach the log so I can see what it reports
                  Cheers,
                  Bob
                    sorry
                    ran the script it creates an empty file tried it 3 or 4 times with the same result
                      It is not finding your locks them
                      I would delete them from HS3 and re-add them
                      Cheers,
                      Bob
                        sorry
                        it is not worth it to me to uninstall the locks and delete them from the system and then readd them and reprogram all of the events they trigger I there is no other way to solve the issue I will just not use the plugin
