This past weekend I had to replace a switchlinc. I pulled out the old one, put the new one in. Logged into the ISY Admin console and added the new device address. Then right clicked on the old switchlinc and ran the replace with function. This went and configured the new switchlinc with all the settings and links from the old switch, removed the old switch and renamed the new switch to the old name. Everything is working from the switch, control linc's, etc....
But when I went into HS, I noticed the status was not correct for the switch. I also noticed that I can not control it from HS. After further investigation, I notice that the Address, Technology Address, ISY Plugin Device Filter ID are all still showing the old SwitchLinc address.
Is there a way to force this to update or a way to update it to the correct new SwitchLinc address?
