All of a sudden I see there is no UPB communication. Ran upstart, worked and controlled without issues.
What do you think is the issue? Unplugged the PIM replugged it. The upstart works but HS UPB Spud gives these messages.
Jun-22 06:50:26 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 9 [0714F609FF30B7] to PIM -- timed out 5 times -- discarding message
Jun-22 06:51:12 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 8 [0814F607FF223C8A] to PIM -- timed out 5 times -- discarding message
Jun-22 06:51:57 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 10 [0714F60AFF30B6] to PIM -- timed out 5 times -- discarding message
Jun-22 06:52:42 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 11 [0714F60BFF30B5] to PIM -- timed out 5 times -- discarding message
Jun-22 06:53:27 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 12 [0714F60CFF30B4] to PIM -- timed out 5 times -- discarding message
Jun-22 06:54:12 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 13 [0714F60DFF30B3] to PIM -- timed out 5 times -- discarding message
Jun-22 07:00:14 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 18 [0714F612FF30AE] to PIM -- timed out 5 times -- discarding message
Jun-22 07:00:30 Device Control Device: 1st Floor Interior Downstairs Hall to Off (0) by/from: CAPI Control Handler
Jun-22 07:00:59 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 12 [0814F60BFF2200C2] to PIM -- timed out 5 times -- discarding message
Additional logging.
Jun-22 07:12:42 Plug-In Shutting down Plug-In: UPBSpud
Jun-22 07:12:42 Info Plugin UPBSpud with instance: has disconnected
Jun-22 07:12:50 Info Plugin UPBSpud has connected. IP:127.0.0.1:55115
Jun-22 07:12:51 Plug-In Finished initializing plug-in UPBSpud
Jun-22 07:13:04 Plug-In Shutting down Plug-In: UPBSpud
Jun-22 07:13:04 Info Plugin UPBSpud with instance: has disconnected
Jun-22 07:15:00 Log Info The log database is currently 14.17MB in size.
Jun-22 07:16:14 Info Plugin UPBSpud has connected. IP:127.0.0.1:55514
Jun-22 07:16:14 Plug-In Finished initializing plug-in UPBSpud
Jun-22 07:16:24 Plug-In Shutting down Plug-In: UPBSpud
Jun-22 07:16:24 Info Plugin UPBSpud with instance: has disconnected
Jun-22 07:16:58 Info Plugin UPBSpud has connected. IP:127.0.0.1:55655
Jun-22 07:16:58 Plug-In Finished initializing plug-in UPBSpud
Jun-22 07:17:40 Device Control Device: 1st Floor Interior Downstairs Hall to Off (0) by/from: CAPI Control Handler
Jun-22 07:17:42 Device Control Device: 1st Floor Interior Downstairs Hall to Off (0) by/from: CAPI Control Handler
Jun-22 07:17:43 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 1 [0714F601FF30BF] to PIM -- timed out 5 times -- discarding message
Jun-22 07:17:44 Device Control Device: 1st Floor Interior Bay China Lamp to Off (0) by/from: CAPI Control Handler
Jun-22 07:18:28 UPBSpud ERROR PIM_SEND:: ERROR: Unable to send message ID 1 [0814F602FF2200CB] to PIM -- timed out 5 times -- discarding message
END
Additional logging.
END
