Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer IFTTT Channel Integration
HomeSeer IFTTT Channel Integration General Discussion of HomeSeer's IFTTT Channel
Old February 11th, 2017, 10:41 AM
Ramymounir Ramymounir is offline
error in log
i keep getting this in the logevery 30 seconds .. not sure why
Feb-11 4:40:10 PM IFTTT ERROR System.ArgumentOutOfRangeException: Value should match pattern '\A(?/(.|[\r\n])*)?|(ns:[0-9]+(/.*)?))\z' Parameter name: path at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at HSPI_IFTTT.FolderMonitoring.d__14.MoveNext()
Old February 11th, 2017, 11:12 AM
sparkman's Avatar
sparkman sparkman is offline
This looks to be an error with spud's IFTTT plugin, not the native HS IFTTT integration, so you may want to post it in the forum for his plugin to ensure he sees your post.
Cheers
Al
Old February 11th, 2017, 01:15 PM
yes my mistake
so it possible to integrate IFTTT with homeseer without the plugin?
Old February 11th, 2017, 01:20 PM
sparkman's Avatar
Originally Posted by Ramymounir View Post
yes my mistake
Yes, there's a HS channel on IFTTT. You need to enable json and activate the MyHS service.
Cheers
Al
Old February 11th, 2017, 08:11 PM
Sorry i have no knowledge in this matter.. how do i enable json and how to enable the HS service
Old February 11th, 2017, 08:23 PM
sparkman's Avatar
https://www.homeseer.com/ifttt.html
Old February 12th, 2017, 08:36 PM
thanks for the link...
what did you mean by enable json i see this word in a lot of posts.. it wasn't in link with the steps you sent me
Old February 12th, 2017, 08:43 PM
sparkman's Avatar
Under Tools - Setup and then the Network tab, the following settings are available:
On the devices that you want to make available to IFTTT, you need to go to the Status-Graphics tab for them, and pick Control Use values for them:
Hope that helps.
Cheers
Al
Old February 13th, 2017, 01:20 PM
in the case that the trigger is initiated by homeseer device the only 2 options available on ifttt.com are ( if a device is turned on) or (if a device is turned off) right?
while in case of Action : it can be anything
why is that?
I mean for example if i want an event that doesn't start with a device turns on or off what can i do?
US Robotics modem error "Error in command AT+CPMS? : ERROR" jan.vanbezouw@gmail.com SMS Gateway (3P) 5 December 22nd, 2016 06:00 AM
Getting Error 8021 (Internal error retrieving device control block for the port) MasterMog WAF-AB8SS (3P) 6 September 16th, 2006 05:44 AM
8/15/2005 5:37:40 PM Error Error Sending email: 502 Error: command not implemented paul@thekaufs.com HS2 / HSPRO 0 August 15th, 2005 06:27 PM
Help with Error Message, Script error in file: CH and HW Control temp.txt 0: in line 0 nigelgiddings Script & Plug-In Development 1 August 2nd, 2002 04:20 PM
