Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help
HomeSeer Help Help, How-to's and Documentation
Old February 27th, 2017, 12:01 PM
acromion acromion is offline
Parse text on new line from script
I am attempting to parse out some text from a device (the thinking cleaner plugin for my Roomba) into discrete fields. This should be a simple task but I can't get it to work. The motivation for this can be seen here: https://forums.homeseer.com/showthread.php?t=173509
The text is:
Status: On homebase: Trickle Charging
Model: 600
Battery charge: 88 %
Total cleaning distance: 299.30 KM
Total cleaning time: 277 hours 8 minutes
Last cleaning took: 0 hours 0 minutes
This is the script that I have:
Sub Main(parm as object)
Dim sVal
sVal = hs.devicestring(514)
dim splitVal() as string
splitVal = sVal.split(Chr(13))
hs.WriteLog("Info", splitVal(0))
hs.SetDeviceString(532, splitVal(0),True)
End Sub
The trouble is that it doesn't actually split on Chr(13) as I would expect. Instead I end up with everything in splitVal(0) and nothing in splitVal(1). I can replace this with ":" and it splits fine. I've also tried "/n", "/r", Chr(10), and Environment.NewLine without success. This seems very simple but I can't figure out where I'm going wrong. Any ideas?
Old February 27th, 2017, 12:06 PM
sparkman's Avatar
sparkman sparkman is offline
This might work:
Dim sVal
sVal = sVal.Replace(Chr(13), "")
splitVal = sVal.split(Chr(10))
End Sub
Old February 27th, 2017, 12:14 PM
Now I get this in the log:
Running script C:\Program Files (x86)\HomeSeer HS3\scripts\parseroomba2.vb :Exception has been thrown by the target of an invocation.Public member 'split' on type 'String()' not found.
Old February 27th, 2017, 12:33 PM
I figured it out. The text was showing carriage returns and line feeds when I cut and pasted it into a text editor but the actual ascii codes in the original text simply had a <(nospace)br(nospace)> at the end of each line. If I split based on that it works.
Thanks for the help.
Edit: Had to put the (nospace) filler in there so it wouldn't get interpreted instead of printed.
Old February 27th, 2017, 12:47 PM
sparkman's Avatar
Sorry, had messed up the code. It's fixed now, but looks like you have it resolved.
Cheers
Al
HTML code is On
is it possible to parse wildcard to text? eliashall Kinect (3P) 1 May 17th, 2015 07:09 AM
Script Help - Parse JSON VB.net skarragallagher HS2 / HSPRO 17 November 26th, 2013 04:50 AM
You can use a single script line of text to toggle a device in the button skybolt HSTouch™ 0 January 7th, 2009 02:22 PM
Parse Out Last line in Text File JFTLNG Script & Plug-In Development 4 July 31st, 2006 11:49 AM
example script to parse email & extract text? alevey Script & Plug-In Development 6 January 10th, 2003 12:57 PM
