Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help
HomeSeer Help Help, How-to's and Documentation
Old March 12th, 2017, 01:56 PM
rgraham1 rgraham1 is offline
CAPI question
My outdoor X10 floodlights are being turned on without explanation.
I see the following line in my Log file randomly several times per day:
Mar-12 1:28:01 PM Device Control Device: Outside Garage garage door floodlights to On (100) by/from: CAPI Control Handler
Can anyone explain why? Or what is going on?
thanks,
Ron
Current Date/Time: 3/10/2017 3:26:24 PM
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.297
Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 2 Days 18 Hours 9 Minutes 11 Seconds
IP Address: 192.168.1.2
Old March 12th, 2017, 05:29 PM
mrhappy mrhappy is offline
These entries suggest that the lights are being turned on by HomeSeer which is a relief with X10 that it is not a rogue signal. It unfortunately does not narrow it down any more, it can be via the web interface, HSTouch, an event or a script. That does not help I know but what I would suggest is checking your events, in the top of the events page you should see the option to filter by device. If you select the flood lights then take a look to see what events control that device, you might find it is turning on after being left in an event by accident.
Old March 12th, 2017, 06:41 PM
thanks for the info.
I'm going to try to eliminate some of the variables.
I'll start by unchecking the Setting for the flood lights (I'll keep the logging)
Status Only Device:
Is Dimmable:
Hide device from views:
Do not log commands from this device:
Voice command:
Confirm voice command:
Include in power fail recovery:
Use pop-up dialog for control:
Do not update device last change time
if device value does not change:
HTML code is On
CAPI Questions jwshome2 HS3 / HS3PRO Discussion 5 March 20th, 2016 07:10 AM
CAPI Gallina HS3Touch™ 3 March 15th, 2016 10:23 AM
OK Capi!!! Help Gogs HS3 Scripting 35 April 24th, 2015 05:11 PM
CAPI? MrSkippy HS3 Scripting 2 April 4th, 2014 06:54 AM
Help with CAPI please naellis HS3 Scripting 4 March 26th, 2014 09:03 AM
