OMNI Plugin v3.0.2.2
    Originally posted by Pete View Post
    Removed the HAI plugin and shut down the Omni Plugin. Shut down Homeseer and rebooted PC.
    Still seeing this in logs:
    9/2/2017
    Sep-02 8:15:53 PM Info Plugin OMNI has connected. IP:127.0.0.1:43786
    Sep-02 8:15:54 PM Warning Attempt by plugin to register a duplicate link of Logs. Plugin: OMNI Instance:
    Sep-02 8:15:56 PM Plug-In Finished initializing plug-in OMNI
    Removed Omni Plugin. Shut down Homeseer and restarted PC.
    Installed Omni Plugin. Shut down Homeseer and restarted PC.
    Enabled Omni Plugin.
    9/2/2017
    Sep-02 9:01:37 PM Info Plugin OMNI has connected. IP:127.0.0.1:54472
    Sep-02 9:01:37 PM Warning Attempt by plugin to register a duplicate link of Logs. Plugin: OMNI Instance:
    Sep-02 9:01:39 PM Plug-In Finished initializing plug-in OMNI
    Sep-02 9:09:13 PM Warning File does not exist: /HomeSeer/html/HAI
    Still same with new error.
    Is the plugin running? That message is just a warning.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      Yes. That is the message I get when I enable the plugin.
      Only thing is that I cannot turn on logs or console logs.
      IE: turn them on, leave the Omni Menu to the Homeseer main menu, return to the Omni Menu and notice that the logs are disabled.
      Looked at the Homeseer directory with explorer and noticed a /HomeSeer/Homeseer/html/Omni and /HomeSeer/Homeseer/bin/Omni directory. They were both empty.
      Omni system devices are not updating. Note historically HAI DCM status never changed from error and it has been fine.
      Not sure about the May 2017 date and why it is there and where it came from. Currently have no events / triggers running.
      [ATTACH]63161[/ATTACH]
      Aux Temperature/Humidity and Temperature sensors appear to be updating fine.
      [ATTACH]63192[/ATTACH]
      Some Omnistat devices are updating while others are not.
      [ATTACH]63188[/ATTACH]
      Zones appear to be updating fine.
      [ATTACH]63190[/ATTACH]
      Units appear to be updating fine.
      [ATTACH]63191[/ATTACH]
        Decided this morning to disable the plugin and delete all of the Omni Variables one group at a time baby steps fashion:
        1 - Disabled plugin and removed all system variables and enabled the plugin.
        System variables were created with current date. Only have seen battery variable change from the point in time it was created.
        2 - Disabled plugin and removed all thermostat variables and enabled the plugin, enabled the omnistat and had it create new thermostat variables. Variables updated to time of enabling. No changes from the time of creation of omnistat variables.
          Wondering what Omni system variables are supposed to update?
          I have not seen any changes since removing old ones and having the Omni Plugin create new ones.
          Zones, Units, aux temperature/humidity stuff changes.
          Logging on and off switch is still an issue.
            Those should update anytime they change in the panel.
            In PC Access, go to the Status/Control tab and they should match.
              #21
              Thank you Rob.
              PCA shows:
              [ATTACH]63208[/ATTACH]
              Omni Plugin shows. DCM never changes from error.
              [ATTACH]63209[/ATTACH]
              I have not tested power, disconnecting phone line yet.
              HS2 HAI plugin shows a few more status values:
              [ATTACH]63210[/ATTACH]
              Can't enable the logging switches such that they stick.
              The load log function works and does delete the log from view.
              [ATTACH]63211[/ATTACH]
                #22
                @Rob,
                Noticed a similar issue with enabling HS Touch detailed logging with HS3 V.357.
                The detailed logging switch keeps automagically disabling itself.
                  #23
                  New version posted:
                  https://forums.homeseer.com/showthread.php?t=190870
