Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer IFTTT Channel Integration
HomeSeer IFTTT Channel Integration General Discussion of HomeSeer's IFTTT Channel
Old September 4th, 2017, 07:13 PM
gnichols gnichols is offline
Seer Plus
Changing IFTTT Credentials in Applet
How does one go about changing the username and password for MYHS after it's already been entered in the IFTTT applet?
I've deleted the app and rebooted the iPhone. When I re install the IFTTT app it comes back with all the login credentials still there.
Old September 5th, 2017, 12:56 PM
Seer Plus
Checkbox Solved
Well, It looks like if you wait long enough, it figures out that it can't get to HS and allows you to change the login credentials. It took 3 or 4 hours.
Old September 5th, 2017, 09:29 PM
Seer Plus
Thumbs up Solved again
I just discovered if you go to the search screen and search for HomeSeer and then touch the HS icon that appears. In the upper right corner is a gear. Touch the gear and it will take you to a screen where you can change the log in credentials.
IFTTT applet failed Richel HomeSeer IFTTT Channel Integration 0 August 7th, 2017 10:11 PM
HS3Touch Camera Credentials Club Chapin HS3Touch General Discusion 2 June 22nd, 2017 12:26 AM
Storing credentials phuz HS3 Plug-In Development 5 March 16th, 2017 05:49 PM
java applet jon00 Script & Plug-In Development 0 January 9th, 2004 06:20 PM
