Hi Blade and All,
Just built a new HS3 machine using BL1Wire with a TEMP08. I have configured the Plugin on com port 8, the settings are
9600 8 none 1 none as per midon instructions.
The plugin was running O.K. on the old machine and stopped in mid June although at the time I did not get a chance to check it out. Not sure if that is a clue.
Suffice to say it is not running on the new machine at all. If I select com 8 using Putty and typing INI I see plenty of data on a regular basis.
I am unable to open the com port from the Plugin Options page no matter what I have tried. Re starting HS, Restarting Windows, Disabled / Re enabling the Plugin. I have also set the buffer to its lowest setting hoping that it will make a difference. Really not sure what to try next although if memory serves me correct it has always been a little tricky to get it to start.
Hope some one can give me a pointer.
Peter
Peter
