If you are using the plugin, PHLocation, there is a new feature in weatherXML called Follow Me.
Go to the weatherXML Plugin Integration page. If PHLocation is installed and active, a new section will display.
Follow Me allows you to use PHLocation to track your location and to have weatherXML keep one of its locations updated with the weather information for where you are.
Now where ever you are, you can have the weather info for that location.
Follow Me works with any of the weatherXML Providers that use a Lat and Lon.
Setup is four dropdowns.
The first dropdown is where you select the weatherXML location that will be used for following you.
The next dropdown is where you select the PHLocation device for Latitude.
Under that is where you select the PHLocation device for Longitude.
The last dropdown is where you select the PHLocation device for City.
After the location is setup, from then on whenever the current conditions is run, weatherXML will look up the Lat, Lon and City of where your phone last reported that you are. It will change the weatherXML location to use the Lat and Lon from PHLocation. It will also use the City name for display.
A Future release will allow you to use PHLocations New Location or New City trigger to have weatherXML update the location as soon as your phone reports in to PHLocation.
More info on PHLocation is available at: http://forums.homeseer.com/showthrea...ght=PHLocation
