In Homeseer 2, scripters had a simple method to control devices using hs.ExecX10 and hs.Transmit commands. HST removed the functionality in Homeseer 3 and replaced it with CAPI control. This requires far more coding and is much harder/complex for the occasional scripter.
Do you think that HST should provide a new scripting command to control devices in HS3? If you agree, please post ideas how this would be implemented bearing in mind that there is now no standard for On, Off etc and is plugin dependant.
