Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3 / HS3PRO Discussion
HS3 / HS3PRO Discussion Discussions related to the released version of HS3/HS3PRO
Old November 18th, 2014, 10:51 AM
rayvino rayvino is offline
Seer Plus
Events to turn on AC only when Humidity high?
I'm looking for the best way to set up Events in HS3 to only set the AC to 80 degrees when the Humidity is 62% or greater, otherwise turn off AC. I have a 2nd home in Florida with 3 - 2Gig CT100 thermostats.
1) Below is how I have the event set but I think there must be a better way, I also need to have a separate event to turn AC Off if humidity is less than 62%
2) What happens if humidity is exactly 62% (I don't see an equal to or greater than option)
3) Is it not possible to combine this into one event? If humidity is greater than 62% set ac to on & 80degrees OR IF humidity is less than 62% turn AC off, I am unable to drag the OR IF statement after the first Then statement?
Any ideas, suggestions would be appreciated. (also how do I embed the screenshot directly into a post?) thanks
IF Thermostat Living Area Liv Area Relative Humidity was set and has a value that is greater than 62 %
Then Set Device Thermostat Living Area Liv Area Thermostat AC/Heat to Cool
Then Set Device Thermostat Living Area Liv Area Thermostat Cooling Setpoint to 80 F
Old November 18th, 2014, 11:50 AM
cheeryfool's Avatar
cheeryfool cheeryfool is online now
Super Seer
I think you are on exactly the right track. You would need two events. Set the "On" event to kick-in when the humidity is >61% and the "Off" event to kick in when humidity is <62% - assuming that the humidity is measure in integers.
I have a Nest t-stat and they just added humidity to the API and Spud has implemented that in his Plugin, however, the Nest only reports humidity change every 5% !!
cheeryfool
Old November 19th, 2014, 09:25 AM
Seer Plus
thanks!
HS3 CPU too high Stevieboy HomeSeer General Discussion Area 17 November 8th, 2014 02:53 PM
Is there a way to turn off "Future VR events"? johnwpb Voice Recognition (ASR) Hardware 2 February 16th, 2009 06:44 PM
High cpu jtwolf76 SeerAMP (3P) 1 January 8th, 2007 03:32 AM
CPU at High 97 -100 % Richard HomeSeer General Discussion Area 18 February 26th, 2005 01:28 PM
