Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Rien Du Pre Plug-Ins > Caddx
Caddx This is the discussion area for the Caddx plug-in.
Old July 20th, 2015, 12:07 PM
Raptor's Avatar
Raptor Raptor is offline
Seer Master
New Device Icons
this one is pretty low on the importance scale, but homeseer just released a new icon set:
http://board.homeseer.com/showthread.php?t=175159
and i would love to see these in the Caddix plugin,
i have changed a few over myself,
i was wondering if there were any plans to change over the graphics globally in the plugin?
thanks
Raptor
HS3 Pro on Windows 8 64bit
53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
Check out my electronics blog here:
https://www.facebook.com/RaptorsIrrationalInventions
Old July 20th, 2015, 01:21 PM
misraels's Avatar
misraels misraels is offline
Seer Master
I too have switched over to the new HS icons.
I would suggest giving users a choice to use the new HS standard icons which are theme based, or the existing icons. Or at least give us an ini file or something where we can point each item to a specific image.
HS Install Date: Feb. 16, 2007
HS3 Pro, Z-Wave, Insteon, BLStat, HS Touch Server, MyQ
WeatherXML, BLBackup, BLLAN, BLLock, Restart, CaddX, OpenSprinkler
Old August 4th, 2015, 09:27 AM
Rien du Pre's Avatar
Rien du Pre Rien du Pre is offline
Seer Master
I will add this functionality in the next version !!!
Regards,
Rien du Pre
The Netherlands
Using:
Homeseer PRO 3.0.0.368 on MacOS - Running a Mac Mini
Plugin's:
A10, HStouch, RFXCOM, Plugwise, Caddx, HarmonyHub, BLShutdown, BLLogMonitor, BLRadar, BLBackup, FritzBox, Log2Text, BLLAN, PHLocation, ThinkingCleaner, IPThermostat, Z-Wave
Link to the forum of my Plug-ins http://board.homeseer.com/forumdisplay.php?f=1216
HTML code is On
Two icons for the Same device can it be changed? Rotech BLRadar (3P) 18 November 26th, 2013 04:23 PM
Device Icons in HSTouch nightwalker HSTouch™ 2 December 26th, 2008 09:55 PM
Changing Device Icons? mbreeden HS2 / HSPRO 7 August 22nd, 2005 12:57 PM
Change Device Icons MeSteve HomeSeer General Discussion Area 14 November 16th, 2004 05:38 AM
Adding device icons in webpage? SWEET GT Web Server and Interface 4 November 13th, 2002 02:38 PM
