Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Rien Du Pre Plug-Ins > Caddx
Caddx This is the discussion area for the Caddx plug-in.
  #41
Old November 2nd, 2016, 02:04 PM
integlikewhoa integlikewhoa is offline
Seer Master
Quote:
Originally Posted by Rien du Pre View Post
I found a typo, which causes a number of issues.
New version will be in the updater in 5 min.
I got an error during updating twice.
Quote:
Nov-02 11:21:32 AM Updater Install/Update of package Caddx was successful.
Nov-02 11:21:32 AM Updater Copying file: \usr\local\HomeSeer\Docs\HomeSeer Caddx plug-in V3.1 documentation.pdf
Nov-02 11:21:32 AM Updater Copying file: \usr\local\HomeSeer\HSPI_Caddx.exe
Nov-02 11:21:32 AM Updater Extraction Complete.
Nov-02 11:21:32 AM Updater Extracting files from zip file: /usr/local/HomeSeer/Updates3/Caddx3.4.1.0/CADDX_Images.zip Destination: /usr/local/HomeSeer/html/images/Caddx/
Nov-02 11:21:32 AM Updater Installing package Caddx
Nov-02 11:21:32 AM Updater Update hspi_Caddx.exe downloaded successfully
Nov-02 11:21:26 AM Updater Downloading update: Caddx
Nov-02 11:21:26 AM Updater Error saving the downloaded file: error
Nov-02 11:21:26 AM Updater Error downloading package :An exception occurred during a WebClient request.
Nov-02 11:21:26 AM Updater Downloading update: Wait Caddx Waiting for Server...
Nov-02 11:21:26 AM Updater Starting download of updates
Nov-02 11:20:18 AM Updater Install/Update of package Caddx was successful.
Nov-02 11:20:18 AM Updater Copying file: \usr\local\HomeSeer\Docs\HomeSeer Caddx plug-in V3.1 documentation.pdf
Nov-02 11:20:18 AM Updater Copying file: \usr\local\HomeSeer\HSPI_Caddx.exe
Nov-02 11:20:18 AM Updater Extraction Complete.
Nov-02 11:20:18 AM Updater Extracting files from zip file: /usr/local/HomeSeer/Updates3/Caddx3.4.1.0/CADDX_Images.zip Destination: /usr/local/HomeSeer/html/images/Caddx/
Nov-02 11:20:18 AM Updater Installing package Caddx
Nov-02 11:20:18 AM Updater Update hspi_Caddx.exe downloaded successfully
Nov-02 11:20:11 AM Updater Downloading update: Caddx
Nov-02 11:20:11 AM Updater Error saving the downloaded file: error
Nov-02 11:20:11 AM Updater Error downloading package :An exception occurred during a WebClient request.
Nov-02 11:20:11 AM Updater Downloading update: Wait Caddx Waiting for Server...
Nov-02 11:20:11 AM Updater Starting download of updates
The Updater is still showing that I have 3.4.0.0 and 3.4.1.0 is available even after the two attempts above.
  #42
Old November 2nd, 2016, 02:05 PM
Rien du Pre's Avatar
Rien du Pre Rien du Pre is offline
Seer Master
Stop the Caddx plugin before upgrading, this will usually help.
I found another issues with triggers, but this one if difficult to solve....
Regards,
Rien du Pre
The Netherlands
Using:
Homeseer PRO 3.0.0.368 on MacOS - Running a Mac Mini
Plugin's:
RFXCOM, Caddx, HarmonyHub, BLShutdown, BLLogMonitor, BLRadar, BLBackup, FritzBox, Log2Text, BLLAN, PHLocation, Z-Wave
Link to the forum of my Plug-ins http://board.homeseer.com/forumdisplay.php?f=1216
  #43
Old November 2nd, 2016, 02:09 PM
Seer Master
It was stopped before both of those I just didn't copy those lines. Also something else that has always been fishy about this updater and caddx is that down under the security tab when searching for a plugin. It doesn't show an installed version there. It just shows a current version like it doesn't know I have it installed. But up at the top where my installed plugins are it is there and shows the installed version with the new version and check box next to it. none of my other plugins do this.
Quote:
Nov-02 11:21:48 AM Plug-In Finished initializing plug-in Caddx
Nov-02 11:21:45 AM Caddx InitIO called, plug-in is being initialized...
Nov-02 11:21:45 AM Info Plugin Caddx has connected. IP:127.0.0.1:42462
Nov-02 11:19:17 AM Info Plugin Caddx with instance: has disconnected
Nov-02 11:19:17 AM Plug-In Shutting down Plug-In: Caddx
  #44
Old November 2nd, 2016, 02:59 PM
Seer Master
I'm not sure if this issue is only with my install or if anyone else is seeing the same but I'm still not able to update mine.
Do you have a link for the file to manually update?
I shut down the plugin, grabbed the files from the "/usr/local/HomeSeer/Updates3/Caddx3.4.1.0" and manually replaced the .exe, started the plugin backup, refreshed the updater, and it still shows I'm running 3.4.0.0 in the updater.
  #45
Old November 2nd, 2016, 04:00 PM
askme askme is offline
Seer Deluxe
Just checked and despite having updated (I thought) to 3.4.1.0, I was showing still showing 3.4.0.0. The Plugin Mgt page also only showed 3.4.0.0 as available.
I had to run the "update" on the plugins mgt page. Now it shows 3.4.1.0. Disconnected from Panel, shut down Caddx plugin, ran the update from the Mgt page, and now show 3.4.1.0.
Incidentally, that also solved my other issues. I will update that thread.
  #46
Old November 2nd, 2016, 04:03 PM
Seer Deluxe
FIXED: fantastic. Thanks.
  #47
Old November 2nd, 2016, 09:09 PM
Seer Master
I was able to remove all config and exe files for caddx plugin then install from updater and then put back the config files. That now shows new version installed in updater. But i still had the same install errors.
  #48
Old November 3rd, 2016, 01:00 PM
Seer Master
Glad you got working. The updater is sometimes unpredictable.
  #49
Old November 3rd, 2016, 01:05 PM
Seer Master
Still waiting to see if I have that rouge window show open, but that doesn't happen everyday or I'm not sure what triggers it.
What was the issue with the triggers that you found and were you able to find a workable solution for them? What should we expect to see happening with the current issue?
  #50
Old November 3rd, 2016, 01:08 PM
Seer Master
It was something in my environment and I had to adjust the event triggers and now the error is gone.
If you don't have any events with partition triggers yet, you won't run into this issue and new ones are created correctly.
  #51
Old November 3rd, 2016, 01:18 PM
Seer Master
Great, thanks for the update.
HTML code is On
Love KODI? Eman HomeSeer General Discussion Area 14 July 17th, 2016 08:50 AM
So much love for AP800? silverbeard Voice Recognition (ASR) Hardware 0 March 8th, 2009 12:44 AM
I love yours site AlexCoppas HomeSeer General Discussion Area 5 May 8th, 2006 03:41 AM
