I have experienced sporadic, infrequent loss of event triggering based on received X10. All other event triggers appear to continue to work as normal, and the X10 signals reception is still dutifully logged in the HS log. Below is an excerpt from last night's log. (I suspect the reason that some X10 signals are repeated is that there were a succession of X10 commands and my Compose firewalls buffer and repeat commands that may be subject to collision. That situation is not uncommon, and while it may be a contributing factor, it certainly happens much more often than the loss of X10 triggering.)
It should be evident with some inspection that the same triggers are present in succession, but at 8:14:25 the X10 event triggering stops with no error. I've included a few more failed triggers, but no X10 triggering persisted until this morning, when I restarted HS and restored normal function.
Has anyone else seen this? Any ideas as to what may cause it / how to fix it? Any ideas for ways to program HS to detect it? !
10/28/2009 8:14:22 PM ~!~X10 Received~!~O2 (Outside Lighting Outside Rear) O Preset Dim 0 * OK start
10/28/2009 8:14:22 PM ~!~Info~!~Event Trigger "Outside Rear Lights String Update" *
10/28/2009 8:14:22 PM ~!~Info~!~Running script in background: Parse O2.vb *
10/28/2009 8:14:22 PM ~!~Return Str~!~O;O2;10;0; * last
10/28/2009 8:14:23 PM ~!~X10 Received~!~D1 ( Lighting Dining Room) D Preset Dim 4 * OK start
10/28/2009 8:14:23 PM ~!~Info~!~Event Trigger "DR Lights String Update" *
10/28/2009 8:14:23 PM ~!~Info~!~Running script in background: SmartParse D1.vb *
10/28/2009 8:14:23 PM ~!~Info~!~Command sent to Lighting Dining Room: D1 Preset Dim Dimval: 5 Data: 0 * last
10/28/2009 8:14:24 PM ~!~X10 Received~!~O2 (Outside Lighting Outside Rear) O Preset Dim 0 * OK start
10/28/2009 8:14:24 PM ~!~X10 Received~!~A6 (RF LtSensor Back Garage Light Sensor) A On (not an event trigger)
10/28/2009 8:14:24 PM ~!~Info~!~Event Trigger "Outside Rear Lights String Update" *
10/28/2009 8:14:24 PM ~!~Info~!~Running script in background: Parse O2.vb *
10/28/2009 8:14:24 PM ~!~Return Str~!~O;O2;10;0; * last
10/28/2009 8:14:25 PM ~!~X10 Received~!~D1 ( Lighting Dining Room) D Preset Dim 5 * Fail
10/28/2009 8:14:26 PM ~!~X10 Received~!~D7 ( Dining Room Fountain) D Off (not an event trigger)
10/28/2009 8:14:26 PM ~!~JDS StarGate~!~Flag [17 (JDS DRB) Changed to OFF
10/28/2009 8:14:27 PM ~!~X10 Received~!~O2 (Outside Lighting Outside Rear) O Preset Dim 0 * Fail
10/28/2009 8:14:28 PM ~!~Info~!~Event Trigger "Performance Monitor" (recurring)
10/28/2009 8:14:28 PM ~!~Info~!~Running script in background: Jon00PerfMon.vben
10/28/2009 8:14:28 PM ~!~Info~!~Event Trigger "Copy IP Pics" (recurring)
10/28/2009 8:14:28 PM ~!~Info~!~Running script in background: CopyIPPics.vb
10/28/2009 8:14:28 PM ~!~X10 Received~!~O2 (Outside Lighting Outside Rear) O Preset Dim 0 * Fail
10/28/2009 8:14:29 PM ~!~X10 Received~!~D7 ( Dining Room Fountain) D Off (not an event triggerr)
10/28/2009 8:14:29 PM ~!~JDS StarGate~!~Flag [17 (JDS DRB) Changed to OFF
10/28/2009 8:14:30 PM ~!~X10 Received~!~O2 (Outside Lighting Outside Rear) O Preset Dim 0 * Fail
10/28/2009 8:14:31 PM ~!~JDS StarGate~!~Flag [51 (JDS SG Running) Changed to ON
10/28/2009 8:14:31 PM ~!~JDS StarGate~!~Load variable `19 (JDS HBeat) with 10
