Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Software (Older Versions) > HS2 / HSPRO
HS2 / HSPRO General discussion about HomeSeer HS2 and HSPRO
Old January 6th, 2011, 07:42 PM
bhusselbaugh
Guest
Posts: n/a
How do I un-install an interface plug in?
Smarthome tells me that I can't install both the 2412 and 2414 plug-ins and that the 2412 is the one I need to work with the 2413 USB Insteon controller. They said they have not figured out how to remove a plug-in. Can anyone help with this? Or, alternately, what do I need to make the Insteon controller I purchased (2413) work?
Thanks in advance.
Old January 6th, 2011, 08:26 PM
Rupp's Avatar
Rupp Rupp is offline
Check the how-to forum for a post on how to remove plugins.
-Rupp
Old January 6th, 2011, 09:20 PM
bhusselbaugh
Guest
Posts: n/a
Thanks but where exactly do I find the how-to forum. When I went to what I thought was the how-to forum, there were no posts.
Thanks.
Old January 6th, 2011, 09:31 PM
Rupp's Avatar
Click on the HomeSeer Message Board above and then slide down to the How-To's forum.
The line above looks like:
HomeSeer Message Board > HomeSeer > Home Automation Software > HomeSeer HS2™ Specific > How do I un-install an interface plug in?
