Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Kazteel Plug-Ins > Insteon Thermostat (3P)
Insteon Thermostat (3P) Insteon Thermostat Plug-in discussion
Old December 9th, 2015, 12:05 AM
field888 field888 is offline
3.0.4.2 Install problem
I installed the latest version today and noticed that my events were missing information. When I attempt to set the heatpoint in the event, the window will not accept either the desired temperature, or an increment/decrement. The event was working prior to the update...any ideas?
Current Date/Time: 12/8/2015 10:51:15 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.208
Operating System: Microsoft Windows 8.1 with Bing - Work Station
System Uptime: 19 Days 5 Hours 27 Minutes 48 Seconds
IP Address: 192.168.1.201
Number of Devices: 150
Number of Events: 137
Enabled Plug-Ins
3.0.15.28479: Blue-Iris
3.0.0.75: HSTouch Server
3.0.4.2: Insteon Thermostat
3.0.5.20: Insteon
1.0.0.2: Restart
3.1.0.2: Sonos
Old December 9th, 2015, 09:12 AM
nfrobertson's Avatar
nfrobertson nfrobertson is offline
Hmm, am update was done in 3.0.4.1 to help with coping events to help them retain values in the copy but I'm surprised that impacted existing events. I will take a look at this after work today.
Nathan
HS 3.0.0.318 (PRO)
Hardware: Napco GEM-P9600 | VenstarT1800 w/Insteon 2441V adapter | Insteon PLM
Plugins HS3: Napco Gemini (mine) | Insteon Thermostat (mine) | Insteon Plug-in (mnsandler) | HSTouch Server (HST)
Platform: Windows 10 Pro 64bit, core2 duo 2.0Ghz, 4GB memory
http://www.kazteel.com/
Old December 9th, 2015, 03:54 PM
update
Not sure if this helps, but the event does actually work properly, the temperature will change according to the value that was previously set. I also added a test event to change the temperature, and that worked also. The only issue seems to be that the window doesn't show the value and subsequently the event can't be minimized because of that.
Old December 10th, 2015, 04:34 PM
Sorry about that. I see what the issue is and have a fix. This was a new bug introduced in 3.0.4.1 when I fixed a different issue with copying Events and maintaining their values.
Look for 3.0.4.3 in the updater later today.
Nathan
Old December 10th, 2015, 08:59 PM
working good, thanks for the quick reply and fix!
New Install Problem CFGuy Media Controller Plug-in (3P) 3 February 20th, 2015 02:28 PM
Install Problem bacoxswain SIP Connector 7 August 11th, 2009 05:18 AM
Problem with First Install klechner HS2 / HSPRO 9 January 19th, 2008 01:11 PM
Help With Install Problem (PLEASE) gelessor HomeSeer General Discussion Area 10 October 3rd, 2005 10:26 AM
Problem with new install jsandlin Hauppauge Capture (3P) 10 April 8th, 2003 04:59 AM
