Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Rien Du Pre Plug-Ins > Caddx
Caddx This is the discussion area for the Caddx plug-in.
Old November 23rd, 2016, 04:57 PM
misraels's Avatar
misraels misraels is offline
Caddx Error
I recently started seeing this in my logs, occurs 8 times in a row about every 20 minutes:
Nov-23 4:12:27 PM
Caddx Error
Plugin: Caddx Error in TestforpartitionTriggers module Object reference not set to an instance of an object.
Nov-23 4:12:27 PM
Caddx Error
Caddx Error: DeSerializing object: Unable to load type hspi_Caddx.classes+trigger required for deserialization.
HS Install Date: Feb. 16, 2007
HS3 Pro, Z-Wave, Insteon, BLStat, HS Touch Server, MyQ
WeatherXML, BLBackup, BLLAN, BLLock, Restart, CaddX, OpenSprinkler
Old November 23rd, 2016, 04:58 PM
misraels's Avatar
and...everything seems to still be working
Old November 24th, 2016, 10:47 AM
Rien du Pre's Avatar
Rien du Pre Rien du Pre is offline
Hi Check all your Caddx events, there must be a problem with one of them. This could happen after the upgrade to the latest version.
After you correct the event, the issues are gone.
Rien du Pre
The Netherlands
Using:
Homeseer PRO 3.0.0.368 on MacOS - Running a Mac Mini
Plugin's:
RFXCOM, Caddx, HarmonyHub, BLShutdown, BLLogMonitor, BLRadar, BLBackup, FritzBox, Log2Text, BLLAN, PHLocation, Z-Wave
Link to the forum of my Plug-ins http://board.homeseer.com/forumdisplay.php?f=1216
Old November 28th, 2016, 11:16 AM
misraels's Avatar
found several events in error, corrected those.
Old November 29th, 2016, 09:50 AM
misraels's Avatar
that did, all clear now, thanks Rien.
HTML code is On
Caddx error - HS3 crash Uncle Michael Caddx 0 July 5th, 2016 12:46 PM
SG - Caddx - HS email68 JDS (Stargate, TimeCommander) 4 November 19th, 2009 10:43 PM
Com error Caddx Plugin twebb72 Caddx (3P) 18 October 18th, 2006 04:59 PM
Elk or Caddx or ?? joeslat HS2 / HSPRO 2 November 6th, 2005 02:47 AM
Caddx.dll Error dem5867 Caddx (3P) 0 April 10th, 2005 04:36 PM
