Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3 / HS3PRO > HS3-Pi Discussion
HS3-Pi Discussion Discussions related to the released version of HS3-Pi for the Raspberry Pi
Old May 19th, 2017, 03:59 PM
cfzone cfzone is offline
Viewer
cannot load web interface after install
hi all,
There is a strange issue with the homeseer i am using. I have replaced the Pi 2 coz of broken one. I have followed instruction and install Zee S2 V2 via HS3PI2boot.zip. Web interface failed to login after installation, but its private IP can ping and go outside. I reinstalled it 2nd time and same thing appear. Is there the bugs with the V2?
Old May 20th, 2017, 08:02 PM
Kerat Kerat is offline
Did you move from a RPI 2 to an RPI3?
Old May 22nd, 2017, 07:56 AM
concordseer concordseer is online now
Check what port your PI/HS3 is using. The default port 80 might be in use by some other server on your network.
Old May 22nd, 2017, 09:21 AM
sparkman's Avatar
sparkman sparkman is online now
Multiple servers on the same network can use the same port. It's only an issue if there is already something using port 80 on the HS server.
Sent from my Phone using Tapatalk
Old May 22nd, 2017, 02:09 PM
Has the OP checked that HS3 is in fact on the correct port. Had a situation recently when my port 8081 that I had configured for HS3 encountered a problem and the HS3 configuration defaulted to port 80 and not realising this the web page would not load when calling it on port 8081
Tags
bug, zees2
EasyTrigger won't load - Failed getting Interface MasterMog EasyTrigger Plug-In (3P) 1 February 4th, 2016 08:08 AM
How do I un-install an interface plug in? bhusselbaugh HS2 / HSPRO 3 January 6th, 2011 09:31 PM
Plugin will not load - install errors jackpod PowerTrigger Plug-In 6 October 11th, 2007 05:20 PM
HS2 Install on Win2003 Missing Web Interface scrites HS2 / HSPRO 22 December 8th, 2005 10:34 PM
Can't install Z-Wave Interface vanderland HomeSeer Z-Wave Plug-in 2 December 28th, 2004 11:21 PM
