Yes I restarted the plugin and the controller
I reset the Smart Bridge Pro and reconfigured with the same IP.
I have had trouble with each upgrade and I remember you asked me how I installed the plugin the first time. I installed the plugin manually. Even after I delete the plugin I see see the files in the HS3 config files. Any way to make sure I have completely cleaned out this plugin and start fresh?
Attached is a screen shot of HS3 advanced tab maybe that will tell you something.
