Here you go. Thanks.
Question about string values not coming through
That's a good question - I was wondering about that also.
I can post in the Nest forum to see what is going on there?
For reference, I didn't notice any issues with the translation of the temp number in MainLobby through your plugin until the latest update I ran. Did the changes you make for the string potentially impact the processing of this field?
Originally posted by simonmason View PostThat's a good question - I was wondering about that also.
Find out what that suffix is after the degree symbol
Bob,
I had to revert to the previous version of the plugin as the latest version had another change that caused issues with my setup.
Most of my lights were showing "On last level" and were not updating with Off an On, etc. I think this was only my z-wave lights but I didn't do enough research to confirm that. The _value was updating to show the dim level 0-100. But in my Mainlobby screens I am depending on the On and Off.
Also, curiously I noticed that the suffix on the HS3 devices in this version of the plugin is being ignored and only the numeric value is showing in MainLobby without any garbage.
I do appreciate you helping out with the changes and I am sorry to have caused further work as a result of this. I would be fine with reverting to the previous version unless you feel accommodating the empty string situation is worthwhile for others!
No, I am using this to display status on the touchpanels.
For example - a family room light. In the plugin I call it fam1 so it shows in ML as hs3_fam1. I then use the {{hs3_fam1}} variable in mainlobby to show whether the light is on or off.
With this recent change it stopped updating and only shows "On last level" whereas before it would show On or Off.
I turn the lights on and off using the following command: MLServeCmd.BLML2HS|HS-ToggleDevice~ID
