Setting up another Elk M1G... wondering if I can use the plugin to run two at once?
Second instance?
Originally posted by gregoryx View PostSetting up another Elk M1G... wondering if I can use the plugin to run two at once?
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Can't one do more than one instance of a plugin with HS3? I thought so.
Theneach instance would connect to a separate Elk,panel.HomeSeer 2, HomeSeer 3, Allonis myServer, Amazon Alexa Dots, ELK M1G, ISY 994i, HomeKit, BlueIris, and 6 "4k" Cameras using NVR, and integration between all of these systems. Home Automation since 1980.
