Originally posted by rprade
View Post
Your board has 2 ways to provide power:
- Through USB
- Through the pin marked Vin
Both will end up at the input side of a onboard voltage regulator that steps it down to the required 3.3v.
If you need 5V to for example power a LCD you can take that from the pin marked VU.
I have seen reports where people use the Vin as a 5V supply when using USB but the version I am using does not seem to have a direct connection to the 5V supplied by USB so mileage may vary.
