I am VERY pleased with the Arduino plugin except for the delay for detecting an input or triggering an output.
In my case:
- Pushbuttons need to be pressed almost 2 secs
- Input are only detected if opened for 1-2 secs
- Blinking a led with a OutputTime of 500 msecs willl give me this pattern:
off for 2 secs, on 500msecs, off 2secs, on 500msecs etc.
Today I had my first loss on an input, the letterbox opening was not detected when the mailman delivered a simple letter, causing the flap to be opened too fast.
Am I alone ? what are your delays ?
Could this be improved by lowering the numbers of I/O on the board, or be board-dependant ?
Pierre
Running HS 3.0.0.318, plugin 1.0.0.39, on a genuine Arduino Mega, 1 Analog, 12 inputs, 9 outputs, 13 1-wire.
In my case:
Pierre
