Go Back   HomeSeer Message Board > User Interface Plug-ins > User Interface Discussion > ImperiHome Plug-in (3P)
  #21
Old August 5th, 2017, 05:41 PM
integlikewhoa integlikewhoa is offline
Seer Master
Quote:
Originally Posted by spud View Post
Have you selected a On/Off device in the device mapping column? you may need to do that.
If that's not the problem, try to see if the device is sent to the app in the trace logs.
I found that when using a dimmer (checking the box) for HSL and HSV my devices don't show in imperihome. Using RGB it shows up. turning off the dimmer on the other two it shows up.
But as you suspected I have tried different configurations and nothing comes close. Colors are all out of whack, sliders don't and throw it off further. Not sure if I can make some virtual devices to bridge the gap but it's a no go right now.
  #22
Old August 18th, 2017, 10:22 AM
Tomgru Tomgru is online now
Seer Deluxe
Spud, new version to test coming soon?
Sent from my SM-G950U using Tapatalk
  #23
Old September 4th, 2017, 01:22 PM
Seer Deluxe
Spud, you give up on this?
  #24
Old September 4th, 2017, 05:12 PM
spud's Avatar
spud spud is online now
Moderator
Quote:
sorry for the delay, I did not give up, I just need to find time to test and debug this properly.
  #25
Old September 5th, 2017, 09:28 AM
Seer Deluxe
  #26
Old October 8th, 2017, 01:11 PM
Seer Deluxe
Hi spud... tried this today and it's close!!!
I have no white... (FYI) channel.
See pic for configuration. I dimming selected, and the same option for each - the main RGB (fibaro) module. In the dashboard, I can turn on/off, and dim from this device.
when I create it in IH, I have the color wheel, and two sliders. Left slider seems to change the color depth (if that makes sense)... from deep to more white.
Right slider I believe is the overall dimmer. but it doesn't do anything when I move it within IH. HOWEVER, it I adjust the dim level directly in HS, the slider reacts within IH ... so it shows correct status from HS to IH, but doesn't adjust from IH to HS.
Make sense?
Just confirming this still works the same way. so close!!!!!!!!
  #27
Old November 9th, 2017, 04:33 PM
spud's Avatar
Moderator
Sorry for the very long delay!
Could you test version 3.0.0.25, I think I fixed the Dim slider, at least on Android, see this thread for more information
  #28
Old November 17th, 2017, 11:53 AM
Seer Deluxe
heck yeah!!! works great.
HTML code is Off
Fibaro Universal module gd1210 HomeSeer Z-Wave Plug-in 4 October 4th, 2016 11:38 PM
Fibaro RGB-module: "Green", "Blue" buttons controls almost entire house! Moskus HomeSeer Z-Wave Plug-in 1 August 21st, 2016 04:57 AM
Fibaro RGBW module U5tabil HomeSeer Z-Wave Plug-in 4 April 21st, 2015 10:54 AM
Including Fibaro dimmer module stuhlej Lighting & Primary Technology Discussion 17 January 17th, 2015 09:06 AM
Random associations on fibaro rgbw module bartbakels Lighting & Primary Technology Discussion 1 January 29th, 2014 04:56 AM
