Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > CFGuy Plug-Ins/Scripts > WeatherXML
WeatherXML Discussion area for WeatherXML
Old November 20th, 2017, 11:34 PM
Mr_Resistor Mr_Resistor is offline
Seer Deluxe
Unable to Update
Currently on 3.0.0.76....tried to update to 3.0.0.79.
Disabled the plugin first and tried to install....fail.
Nov-20 7:29:05 PM Updater Error Installation of package weatherXML failed. Try disabling the plugin first, then re-try the update.
Nov-20 7:29:05 PM Updater Error Unable to open install.txt file for update c:\program files (x86)\homeseer hs3\Updates3\weatherXMLBETA 3.0.0.79
Nov-20 7:29:05 PM Error Error unzipping c:\program files (x86)\homeseer hs3\Updates3\weatherXMLBETA 3.0.0.79\weatherXML30079.zip, Wrong Local header signature: 0x6D74683C on line 0
My home is smarter than your honor roll student.
Old November 21st, 2017, 11:48 AM
CFGuy's Avatar
CFGuy CFGuy is online now
Have A Blessed Day
I made a new zip file. Tested it on both my dev and prod install.
You should be good to install the new beta version .79
Jeff Farmer
HS 3.0.0.312, HSPhone
Other Plugins In Use: APCUPSD, EasyTrigger, FBitSeer, HSTouch Server, Kinect, PHLocation, Pushover, RFXCom, UltraGCIR3, UltraMon3, UltraPioneerAVR3, X10, Z-Wave
Hardware: GoControl Irrigation Controler, Schlage Lever Lock, Schlage Deadbolt, Way2Call Hi-Phone, RFXCom RFXrec433 Receiver, WGL 800, TI-103, Z-Net, Pioneer 1120, Pioneer 1021, Panasonic BDT-110, Panasonic BDT-210 x2
Old November 21st, 2017, 01:46 PM
Seer Deluxe
Same Error..
Nov-21 9:41:18 AM Updater Error Installation of package weatherXML failed. Try disabling the plugin first, then re-try the update.
Nov-21 9:41:18 AM Updater Error Unable to open install.txt file for update c:\program files (x86)\homeseer hs3\Updates3\weatherXMLBETA 3.0.0.79
Nov-21 9:41:18 AM Error Error unzipping c:\program files (x86)\homeseer hs3\Updates3\weatherXMLBETA 3.0.0.79\weatherXML30079.zip, Wrong Local header signature: 0x6D74683C on line 0
I'll try disabling it and restarting Homeseer with it offline and try the update again.
Old November 23rd, 2017, 12:37 AM
Seer Deluxe
Still failing. With Plugin Disabled.
Nov-22 8:35:06 PM Updater Error Installation of package weatherXML failed. Try disabling the plugin first, then re-try the update.
Nov-22 8:35:06 PM Updater Error Unable to open install.txt file for update c:\program files (x86)\homeseer hs3\Updates3\weatherXMLBETA 3.0.0.79
Nov-22 8:35:06 PM Error Error unzipping c:\program files (x86)\homeseer hs3\Updates3\weatherXMLBETA 3.0.0.79\weatherXML30079.zip, Wrong Local header signature: 0x6D74683C on line 0
Old November 27th, 2017, 11:09 PM
Seer Deluxe
Stilly having trouble updating this. Just updated some other plug-ins...... everything worked fine...
Tried to update this one (Plug-in disabled) and get
Nov-27 6:59:27 PM Updater Error saving the downloaded file: error
Nov-27 6:59:27 PM Updater Error downloading package HSPI_WEATHERXML.exe:An exception occurred during a WebClient request.
Any Ideas?
Old November 28th, 2017, 11:43 AM
CFGuy's Avatar
Have A Blessed Day
Are you running HS on windows or Linux?
If Linux, please check this thread:
https://forums.homeseer.com/showthread.php?t=182834
Old November 28th, 2017, 11:48 AM
Seer Deluxe
Windoze 10 Pro. System has plenty of free threads, CPU cycles, disk I/O and memory.
HTML code is On
Unable to Update Bridge Airey001 JowiHue Plug-In 2 May 24th, 2017 07:19 AM
Unable to update Kwikset lock codes after 3.0.0.177? DeVon HomeTroller Zee 3 July 24th, 2015 05:47 PM
Unable to update CE moose HSTouch™ 2 September 20th, 2009 05:10 AM
Unable to update calandar almarsh@gte.net ROC Outlook Interface 1 March 12th, 2003 06:57 AM
