Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > CFGuy Plug-Ins/Scripts > WeatherXML
WeatherXML Discussion area for WeatherXML
Closed Thread
Old May 19th, 2017, 11:41 PM
CFGuy's Avatar
CFGuy CFGuy is offline
Have A Blessed Day
weatherXML Beta
This thread will be to list the changes for the beta versions of weatherXML.
New beta versions will be available in the HS updater in the Beta section near the bottom of the list.
3.0.0.64
This is a huge change. Please make a backup of all your files before testing this version. The tracking of weatherXML HS devices will be tracked by the device address rather than trying to keep them straight in an ini file. You may have to delete and re-add some devices.
* Added a setting to control how many of the backup files to keep. Oldest ones are deleted as new ones are saved.
* Fixed a bug with the download backup that was saving the wrong file for the Alerts backup.
* The map rotation device option is now hidden until at least one map has been setup.
* Added setting to allow selecting which locations will create Global Variables.
* Now tracks the device refIDs based on actual devices instead of storing the refID in an ini file.
* Added the ability to set an image width or height for display on the weatherXML users Map page.
* Added the ability to resize a downloaded Map image
* Fixed the Event device references to work correctly
* Fixed the PHLocation dropdowns to use the Location 1 first setting.
Jeff Farmer
HS 3.0.0.312, HSPhone
Other Plugins In Use: APCUPSD, EasyTrigger, FBitSeer, HSTouch Server, Kinect, PHLocation, Pushover, RFXCom, UltraGCIR3, UltraMon3, UltraPioneerAVR3, X10, Z-Wave
Hardware: GoControl Irrigation Controler, Schlage Lever Lock, Schlage Deadbolt, Way2Call Hi-Phone, RFXCom RFXrec433 Receiver, WGL 800, TI-103, Z-Net, Pioneer 1120, Pioneer 1021, Panasonic BDT-110, Panasonic BDT-210 x2
Old June 7th, 2017, 06:46 AM
CFGuy's Avatar
Have A Blessed Day
3.0.0.68
* More changes to the functions for standardizing the device addresses.
* Fixed an issue with the image rotator device that would not display the dual image from NOAA correctly.
So far in my testing, this version is running with no issues from the change. If no more issues are reported, I will move this out of beta this weekend.
Old June 14th, 2017, 10:12 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.69 & 3.0.0.70
Fixed Map Rotation device to use the new name format for Radar image.
Fixed bug where the Map Rotation device was not incrementing correctly
Old June 25th, 2017, 09:13 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.71
Maps
* Radar is now saved as Radar_1.gif and a second copy with the date in the name to prevent caching in HSTouch.
Location Page
* The Database link on the schedule page no longer shows when no location is set to use an Access database.
* Add a time format dropdown to the location setup
Tide Information
* Added Tide Information devices. Setup is on the HSTouch tab but can be used anywhere that you want to display the information.
* Tide information is no longer stored in an ini file. It is stored in the device plugin extra data.
Misc Devices
* The Last Spoken Log device now has a weatherXML tab that displays all of the current log entries
The tide information is the biggest change. It works like before. Setup a location and set the option "Use Tide Info instead of normal forecast" to Yes. Then you can go to the HSTouch tab to select the devices that you want to use.
Old June 27th, 2017, 08:52 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.72
* Fixed an error that was not downloading the radar image unless you setup both the normal and non cache name.
* Fixed an error when switching from Cumulus File to a different provider the Scheduled does not change from File Watch
* Alert global variables are now set before the alert trigger
* Added code to add the Moon Phase Status Graphics and the Wind Direction Status Graphics
Old July 2nd, 2017, 03:54 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.73
* Removed code that produces the weatherXML javascripts that are in the html/weatherXML directory. These were left over from HS2 and do not work with HS3.
* Fixed issue where the documentation pdfs were not loading.
* Humidity Device is now updating.
* Fixed error causing some of the maps to not build the Device Status Graphics correctly.
Old July 15th, 2017, 08:15 AM
CFGuy's Avatar
Have A Blessed Day
The next beta release is a rewrite of the Maps section.
The ini file will no longer be used.
All maps will now be saved as devices.
On first install of the new version the map device information will be copied from the ini file. The map information will now be edited from the HS device management page. Click on the map name and select the weatherXML device.
IMPORTANT NOTE: If you want a map to be setup in the new version, make sure that you have selected the map to be a device. This should be done before you install the next beta version. (3.0.0.74)
I am just about finished with the documentation and will put the new version in the beta updater when finished.
Old September 9th, 2017, 11:05 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.74
* No longer using an ini file for maps.
* The Map Schedule is set by location, instead of just one schedule does all locations.
* The Map Group parent device now has buttons to add a new map and to Update Group Maps.
* The forecast devices now replace the wind direction abbreviations with the full spelled out text. Ex SW - South west
* The Map Group parent device has a setting to control which directory the maps are downloaded to. The directory must be under the images\weatherXML directory.
* Added the ability to sort the order of the maps on the user map page.
* No more confusing Download and Device checkboxes. All maps are now devices. The download is controlled by the entered URL.
* Added Logging Level to Event Actions. You can now set Event actions to set logging level to Debugging, Do a download and import, set logging level back to Errors.
* Temperature devices in the HSTouch Daily Group now create a Status Graphic for each 10 degree range from -100 to 100 giving the ability to use the Satus graphic in HSTouch and have the thermometer icon change to match the temperature.
3.0.0.75
* New Script to import maps that were missed due to a setting value missing or a map not set to use a device.
3.0.0.76
* Beta release of the alpha changes for .74 and .75
Old October 14th, 2017, 08:30 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.77
* Added number of places to round the UV total.
* Added to forecast: Precipitation Day Forecast, Night Forecast, and Total Day + Night Forecast available in inches or millimeter.
* Added Historical data: Rain totals for any of the past 7 days. Accumulated Rain Totals for past 7 days.
Old November 12th, 2017, 04:23 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.78
* New Event Action: Update Specific Map - This allows you to update a specific map more often then updating every map in a location.
Old November 21st, 2017, 11:51 AM
CFGuy's Avatar
Have A Blessed Day
3.0.0.79 - Fixed an error that caused the support page to not always load.
Old February 20th, 2018, 05:09 PM
CFGuy's Avatar
Have A Blessed Day
3.0.0.81 - Added extra logging to figure out what was causing the PHLocation Lat and Lon to be changed to an integer.
3.0.0.82 - Beta version with error fixed.
Closed Thread
HTML code is On
HS3 Insteon Plug-In Version 3.0.6.38 Beta (Win & Linux)..In Beta section of Updater mnsandler Insteon Plug-in (Mark Sandler) 97 April 29th, 2018 01:18 AM
HS3 Insteon Plug-In Version 3.0.5.88 Beta (Win & Linux)..In Beta section of Updater mnsandler Insteon Plug-in (Mark Sandler) 102 November 15th, 2016 08:48 PM
WeatherXML Beta Issue rmasonjr WeatherXML 2 December 20th, 2012 03:18 PM
WeatherXML beta error rmasonjr WeatherXML 3 December 13th, 2012 06:11 PM
