Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > MCS Plug-Ins and Scripts > MCS Temperature
MCS Temperature Discussions relating to the MCS Temperature plug-in.
Old May 31st, 2011, 04:38 PM
chrkov chrkov is offline
Question Creating Charts via URL issue.
Ok.
Again, I am sure I am just missing something small. I am trying to pull up a chart automatically. But I cant get the Period to change. Here is what I am typing in the url.
http://192.168.150.8/Temperature.asp...&Period=24Hour
But the period always stays at 6Hour.
What am I doing wrong?
Old June 1st, 2011, 12:10 AM
Michael McSharry's Avatar
Michael McSharry Michael McSharry is offline
mcsTemperature chart pages were not designed to operate outside of the context of the mcsTemperatuer pages. It had(s) design provisions to operate effectivley in a low bandwidth environment such as dial-up.
I use xapmcsChart to build pages upon request. This creates the line chart this is intended to be embedded in other displays. In particular I use it out of xapmcsImage to build images for picture frames. xapmcsChart gets its data from the database managed by xapmcsDatabase. xapmcs1wire and xapmcsTemp0x are the application I use to put 1-wire data on the LAN for xapmcsDatabase to collect and for HS to read via mcsXap plugin. This is a long way to go if you are not setup in a distributed xAP environment.
You might be able to make it work with mcsTemperature, but is not something that it was made to do. The top level logic around data received from browser request is below. There is logic elsewhere for transition between pages where the logic is different.
330           s = hsForm("EndDate")
340           If s = "" Then
350               EndDate = FormatDateTime(DateAdd("h", 1, Now), vbShortDate) & " " & hour(DateAdd("h", 1, Now))
360               EndingDate = EndDate
370               DisplayEndDate = "Now"
380               SelectedPeriod = hs.GetIniSetting(TemperatureGroup, "DefaultPeriod", "24Hour", TemperatureIniFile)
390               StartDate = ComputePeriod(SelectedPeriod, EndDate)
400               If sGroup = "" Then
410                    GetGroup hs.GetIniSetting(TemperatureGroup, "SelectedGroup", "Default", TemperatureIniFile)
                  '     SelectedAggregate = hs.GetINISetting(TemperatureGroup, "DefaultAggregate", "None", TemperatureIniFile)
420               Else
430                    GetGroup sGroup
440               End If
450               If (graphStyle = cLine Or graphStyle = cLine2 Or ((graphStyle <> cTable) And alwaysShowGraph)) Then
460                 displayGroups = 1
470                 FormatTemperatureScreen True 'with graph
480               Else
490                 FormatTemperatureScreen False 'without graph
500               End If
510           Else
520               ClientRequest
530               If graphStyle = cColor Or graphStyle = cAllx Then
540                 displayGroups = 1
550               End If
560               FormatTemperatureScreen (graphStyle <> cTable) 'True  'with graph
570           End If
HTML code is On
