Originally posted by travisdh
View Post
HS3 Pushover Plugin
Pushover have introduced a new message priority which apparently has some sort of benefit for those using tasker (it has been some time since I used tasker so it is lost on me), details are here http://updates.pushover.net/post/870...new-priority-2
A new version of the plugin is posted to the top of this thread.
Originally posted by Bill Brower View PostPossible feature request if you have time (HS2/HS3)?
Can you build into the plugin to check a device to code to enable/disable messages being sent?
Something like:
Do not send if )2 is ON
or
Do not send if C2 is OFF
Thank you for the plugin. Simple yet VERY effective.
~Bill
Originally posted by Bill Brower View PostThat was it, occupancy. The Push is a part of events that have several things in it. I think I'll just convert those sub-events to one line scripts with the If built in. Cheers
Bill, could you not just use a virtual device status as a condition for the event in HS3 without themed for this ability to be built into the plugin? The HS3 event engine has this capability natively.
Sent from my iPad using Tapatalk HDAuthor of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
Originally posted by beerygaz View PostBill, could you not just use a virtual device status as a condition for the event in HS3 without themed for this ability to be built into the plugin? The HS3 event engine has this capability natively.
Originally posted by mrhappy View PostI think if I have it right then if I had 20+ events (I've think someone said they have 50 odd events set up to send messages) already set up to send messages it could be a bit painful to go through 20 events manually (which I agree with) and add a condition to evaluate a device before sending the message. I plan on adding a couple of devices to the plugin in the next couple of days when I get some time spare.
You would need to group these events. Edit each one so that they only run if group conditions are met. Then add the condition to the group. This way you can change the group condition in the future and not have to change each event. It is a nice system that was added to HS3 that was not part of HS2._______________________________________________
Something like:
or
~BillLast edited by mrhappy; January 20, 2015, 10:14 AM.
Originally posted by ez1976 View PostWorks GREAT!!!!!
got pushover notifications in less than 2 seconds.
what happens if i go over the limit on the application? can i just create a new one?
