I have a PowerSeries 1616, and have seen the various DSC plugins that require the IT100. I also noticed the Envisalink plugin option. A few quick questions:
- I currently have an ipDataTel BAT device hooked up to my network. I was going to write a plugin, but wasn't able to reverse engineer how to communicate with the device (uses SSL). Has anyone been able to use this?
- What are the pros/cons of the IT100 vs the Envisalink?
- If I get the IT100 and hook it up to a serial to IP converter, will the HS or Blade plugins still work?
