Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HS3Touch™ > HS3Touch Clients - Android
HS3Touch Clients - Android Discussions regarding HS3Touch Clients for Android Devices
  #21
Old October 2nd, 2017, 06:07 AM
brientim brientim is offline
@BeePee thank for the information and I gather you are saying straight out-of-the-box, that Wink is AU compatible.
I would be interest in installing Home Remote; especially given that integrates with HS and has a designer to customise screen layout.
May I ask where did you buy the Wink Relay from?
  #22
Old October 2nd, 2017, 08:08 AM
BeePee BeePee is offline
brientim, Yes that's correct, the wink will work in Aus straight out of the box.
I was prepared to migrate the innards of a small apple style usb charger into it, but found it was unnecessary. There are also reports from individuals who have been running them for several years on 240v.
I purchased mine on Amazon, but the shop who ships internationally is out of stock now. I just purchased another on ebay.
...B
  #23
Old October 11th, 2017, 03:19 AM
I notice in my Wink mobile app there is a new firmware to download.
Version 1.0.602 Is this safe to update without breaking any upgraded features??
...B
  #24
Old October 29th, 2017, 06:54 PM
lj502 lj502 is online now
I noticed the same thing but have not updated yet.
John
  #25
Old November 21st, 2017, 10:09 AM
fran4383 fran4383 is offline
Are you actually able to update it? I don't know if it's because it's rooted or what, but I tried with one of my relays and wink thinks it's updating but it doesn't. I tried to initiate the update from the wink app to no avail. The wink screen went turn off and the app says it's updating until I finally give up and restart the relay. Looks like no more wink updated, which might be ok.
  #26
Old May 15th, 2018, 02:25 AM
mterry63 mterry63 is offline
Following up on the Wink Relay, I finally installed the MQTT wink-handler posted at github here: https://github.com/mjg59/wink-relay-handler
The newest version allows for turning the screen on and off, getting sensor feedback for temperature, humidity, and proximity, as well as controlling/reporting the relay states for the two switches.
Had to reset to factory default to replace the Wink software, but after doing that it was fairly easy. The software works as stated and after a few iterations of adjusting the proximity sensor sensitivity I'm pretty happy with this. Had to reinstall HSTouch as well, but this went smoothly.
With this I no longer have to rely on external sites to control the relays directly. I'm using the basic MQTT plugin posted on the forums. Haven't configured much with MQTT yet, but that seems pretty straightforward.
Total changes - MQTT plugin, Windows Mosquitto broker, and Wink Relay software update.
Now everything is LAN controlled.
Wink kideon HomeSeer General Discussion Area 21 September 23rd, 2016 11:31 AM
Using Wink/Wink Hub with HS3 ryuvann HomeSeer Z-Wave Plug-in 0 August 15th, 2016 07:57 AM
WINK ! Steve LaFleur Message Board Issues, Suggestion, Problems 2 May 7th, 2016 06:28 PM
WINK - Anyone using this? skybolt HomeSeer General Discussion Area 6 March 11th, 2016 08:27 AM
Wink? outbackrob HomeSeer General Discussion Area 60 July 22nd, 2015 12:51 AM
