Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > HomeSeer and Google Home
HomeSeer and Google Home Discussions related to using HomeSeer with the Google Home device
Old November 18th, 2017, 11:58 PM
dannieboiz dannieboiz is offline
No locks showing up?
I can understand the debate here if it was intentional, but why not let us decide?
Old November 19th, 2017, 12:37 AM
Rupp's Avatar
Rupp Rupp is offline
What exactly are you asking here? Currently only on/off/dimmable devices are supported natively.
-Rupp
Old November 19th, 2017, 12:54 AM
When you say natively, does that mean there's a way to show door locks on Google home are alternatively?
Old November 20th, 2017, 04:56 PM
integlikewhoa integlikewhoa is offline
That means you need to mickey a way if you want it to work as google home doesn't allow door lock devices. There might be more then one way to do this, but I would make a virtual on/off button and name it door lock, then use events or other options to link them together. Now your virtual light switch will show up in google home.
I still don't think GH will respond to unlock and lock if it's not natively supported commands in GH.
Old November 20th, 2017, 06:37 PM
I think a virtual switch may do the trick
Old November 20th, 2017, 06:42 PM
You good on making a virtual switch? No plugin needed unlike Vera days.
Old November 20th, 2017, 06:45 PM
I wouldn't say I'm good but I've successfully created a couple specifically for the garage opener and gate opener.
I think I might be able to do the same thing for the lock except for one Goofy work around. Open close is going to be on and off
Old November 20th, 2017, 06:51 PM
btw: the gate/garage is easier since it's a one button activity, so I can simply issue "Ok Google, Activate Garage" and it'll do just that.
The there's a way for us to say Lock/Unlock with it, I'm game.
You should be good.
I mean you can chnage that on the homeseer side, but GH side I'm sure you can do anything about it.
On the Homeseer side go in the virtual device and click the Status graphics tab, Rename the status to locked and unlocked. You will probley have to leave the control by set to on/off (you chould change it but then it probley won't show up in GH like the orginal lock) On the bottom you can also change images for the locked and unlocked.
Old November 20th, 2017, 06:54 PM
You should be good.
I actually have control use set as lock/unlock but google home still thing it's an on/off device.
Old November 21st, 2017, 10:17 AM
ksum ksum is offline
I set up a Shortcut under the More Settings option in the Home App on my phone and now my Home Mini will accept all of the following to open/close the garage door:
  • "...Open the garage door."
  • "...close the garage door."
  • "...open the pod bay door." (because I couldn't resist, Dave)
When I had to reload devices, these still held since they just change one bit of text to another bit. They all are shortcuts for "turn on the garage door." The only part that the picky guy in me wishes was different was the response, which is normally "You got it, turning on the garage door."
Karl S
Old March 23rd, 2018, 03:06 PM
risquare risquare is offline
Thanks Karl.
This does work actually. Thanks for sharing.
Old March 23rd, 2018, 03:39 PM
Hasn't an Open/Close and/or Lock/Unlock ability been added to Google Home capabilities in conjunction with HomeSeer since I posted that suggestion? See:
https://forums.homeseer.com/showthread.php?t=193485
and especially post #9
Of course, I am using a Contact Module and have to run an event to Close then Open the contact a second later, so if you are using this method it may not work. I have not had time to try but would probably end up creating a Virtual Device and apply the settings as mentioned in that thread, if possible.
MorningLinc (Insteon Lock Controller) locks not showing in HSTouch app ClemsonJeeper HSTouch™ 3 May 12th, 2018 03:30 PM
Z-Wave Locks - add multiple users to multiple locks? gregoryx HomeSeer Software 5 October 27th, 2017 03:55 PM
Locks not showing up mistrb HomeSeer IFTTT Channel Integration 6 November 17th, 2016 12:35 AM
PLM Locks up chadg Insteon Plug-in (Mark Sandler) 4 October 14th, 2007 09:19 AM
