Go Back   HomeSeer Message Board > Irrigation Plug-ins > Irrigation Discussion > EZFlora Insteon Irrigation Controller Plug-in
EZFlora Insteon Irrigation Controller Plug-in Discussions of Adam Telford's EZFlora Insteon Irrigation Controller Plug-in
Closed Thread
Old January 30th, 2012, 01:24 AM
hurry4it hurry4it is offline
EZFlora Plugin Revision History
Version 2.0.0.1 (Released 10/30/2013)
New Features
- Added enhanced Insteon error handling and messages. Now the failure of certain messages to be successfully sent will cause the plugin to respond accordingly and all messages that have a transmit failure will log an appropriate error message.
Version 2.0.0.0 (Released 10/05/2013)
New Features
- Added support for HS3.
- Added ability to add and remove individual HomeSeer devices within the device configuration page.
Version 1.1.2.0 (Released 11/10/2012)
New Features
- Added event actions to change EZFlora configuration settings.
The following event actions were added:
- Inhibit Device Operation
- Resume Device Operation
- Enable Rain Sensor
- Disable Rain Sensor
- Enable Pump Control
- Disable Pump Control
- Enable Meter Count
- Disable Meter Count
- Reset Meter Count
Version 1.1.1.0 (Released 04/06/2012)
New Features
- Added Support for viewing/editing manual and program valve timers
Version 1.1.0.0 (Released 02/25/2012)
New Features
- Added brower based device configuration
Revisions
- Reworked error handling
Fixes
- Numerous bug fixes
Version 1.0.1.0 (Released 01/29/2012)
New Features
- Added selectable logging levels
- Added method to unregister devices from Inteon plugin when the EZFlora plugin is shutdown (Requires version 1.6.0.6 or newer of the mnsandler Insteon Plugin)
Version 1.0.0.0 (Released 11/18/2011)
Initial Release
Closed Thread
