Find my iPhone plugin for HS3
    Originally posted by jrhubott View Post
    I will try again with HS to get it into the updater.
    I have also put a new version up that works with Apples new verification. You will get an email when the plugin authenticates. I don't know how often this will occur.
    Jason
    Great news. Will watch this space!
    Cheers
    Steve
    Steve
      Plugin is now in the updater under "Internet or Network Related"
        I tried to update the XML file and save it but it says access denied when trying to save it. Can you advise what I am doing wrong?
          Stop the plugin when you are updating the file then restart it.
          Jason
            Jason
            It says loaded Remotely and Disabled. I will try and restart HS3 and see if that helps.
            Edit: Even with HS3 shutdown it still says access denied.
              One step closer. Still not able to purchase.
                Just got this through the updater working like a charm! Question about the update rate on the geofences, should they be set to 0 or to match the account update setting?
                  Me too. Nowhere to purchase it from ,
                  Not listed when you follow the purchase link :-(
                  Steve
                    Purchasing isn't working (different product in shoppingcart with different price), but more important, the plugin is working!!
                      I sent an email to support describing the problem. Hopefully it will be resolved soon.
                      Brady
                        Brady
                        Hope so. eagerly waiting to get this up and running again. One question, are you able to set refresh rate to 0 so that it can be manually updated with an event ?
                        Cheers
                        Steve
                        Steve
                          Cheers
                          Steve
                          I haven't tried setting to 0, but I do have mine refreshing every four hours and events to manually refresh when I need.
                          Brady
                            Brady
                            I know nothing about scripting but would this mean that HS would be doing something for four hours "waiting" to fire the event, or does it not make any difference wheat her its 10 mins or 4 hrs ?
                            Cheers
                            Steve
                            Steve
                              Everything should now be in the HS3 updater and working. You can also add accounts through the configuration interface. I will be adding additional options to the configuration interface over the next couple of weeks.
                              Let me know of any features you would like in the plugin.
                              Jason
                                Yes, please make it so that I can choose which idevices I want turned into HS devices. I have a slew of iPads and whatnot that showed up. I tried to delete them, but the plugin put them back. I only want our phones there, not all these ipads.
                                Also, I guess that you still have to add the configuration screens for geofencing...as I see no place to enter those. I am new to the plugin, so apologies if you already wrote it somewhere, or if I am supposed to use the ini file until you write the interface.
                                I will test this, and if it goes well, buy the plugin. Thanks.
