Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer UPB Plug-In (Beta)
HomeSeer UPB Plug-In (Beta) Discussion area for HomeSeer's UPB Plug-In
Old April 22nd, 2015, 08:24 PM
Ricky Ricky is offline
HS3 plugin issues - Solved!
I installed the HS3 plug in. The status is listed as "ok" , however there is no drop down menu to assign a com port to the powerline interface. Just a "N/A" is given in the Com column. I have a simply automated serial interface, but the current problem is just assigning a com port to the plug in. Thanks in advance...
I should have said that the powerline interface is working on the hometroller s6. I have configured it with the UPStart program and all my UPB devices have checked out, etc.
I can see in the HS3 log file that the plug in is looking at com1 for the PIM.
Apr-22 5:47:36 PM UPB Initializing UPB PIM on COM port COM1
But I have the PIM at com5. I wonder how I can change that without the drop down menu working in the interface? Is there an *.ini file to edit?
I have put the HomeSeer.upe file in the config directory.
Old April 22nd, 2015, 08:55 PM
Rupp's Avatar
Rupp Rupp is offline
Try clicking on the Plugin Name (UPB) to set options. Once you set your options and go to the bottom and save settings a UPB.ini file will be saved in the config directory. You may have to edit this file for a work around.
-Rupp
Old April 22nd, 2015, 09:48 PM
Yep, that was it . Thanks
Old April 22nd, 2015, 10:03 PM
Rupp's Avatar
What fixed it? Clicking on UPB or setting the com port in the ini file?
Old April 22nd, 2015, 10:29 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Setting the COM port in the ini file? What do you think we are... barbarians??
Old April 23rd, 2015, 01:16 PM
Clicking on the UPB plugin...
Sent from my iPad using Tapatalk HD
HTML code is On
SOLVED Insteon lag issues reidfo Insteon Plug-in (Mark Sandler) 3 May 7th, 2014 04:27 PM
CM11A Issues - Solved! Plane_Guy HS2 / HSPRO 4 January 20th, 2014 08:08 PM
The Device Tab issues - Solved! aldo Clients - Android 3 June 3rd, 2012 10:57 AM
Solved! USB to Serial issues with Z-troller kevini Z-Troller™ 2 April 26th, 2012 09:08 PM
Scripting issues - Solved! simonmason JV Caddx Plug-In 4 November 13th, 2011 09:48 AM
