Originally posted by Sgt. Shultz
View Post
Using HomeSeer's parsing engine for the Echo
Ah.... I thought you were sending it to a lambda function, then down.
You can set up an asp/aspx page as a passthrough..., just process the request in the page and send it to HS3 using the syntax I provided.
If the skill is okay with the endpoint URL that way, that should work.Wade
"I know nothing... nothing!"
Hello,
I have tried the following:
/JSON?request=voicecommand&phrase=turn on kitchen light
However I am always receiving the following no matter what the phrase is:
{ "Response":"Error, bad request" }
I can perform other, documented JSON requests but not this one. I'm running HS3 Standard Edition 3.0.0.208 (Windows). Is this only available in a beta version?HS4, Insteon, Z-wave, USB-UIRT, Harmony Hubs, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, EZVIZ DB1 doorbell
Plugins: BLLAN, BLOccupied, BLUSBUIRT, Chromecast, Harmony Hub, Insteon, Jon00 Homeseer/Echo Skill Helper, Harmony Hub, Jon00 DB Charting, MediaController, NetCAM, PHLocation2, Pushover 3P, weatherXML, Z-wave
I've been using this new JSON feature via Android's automate (http://board.homeseer.com/showthread.php?t=179768). It's awesome. Very fast response. Much quicker than HSTouch even when the app is already open.
Huge request!
Right now, this addition to the JSON API only responds with the default response text as defined in Settings/Voice. Currently, "OK, running the event {event}". At least it appears that is where it is coming from. Additionally, any Speak actions in triggered events are not passed into the response.
What would be great is if you could define a custom response within the 'phrase recognized' trigger that overrides the default response.
I would prefer this over the alternative of passing any Speak action text in the response because I want to be able to selectively skip the default response when a custom phrase is recognized because it takes a while to say. I do however want the default response when I run an event with the generic "Run event {event}" phrase, so I don't want to have to clear that default out and reply on all events having speak actions.
It would also be great if this custom response supported replacement variables like emails and speak actions currently do.
Examples:
What is the house temperature?
70 degrees.
What is the thermostat set to?
71 degrees.
What is the status of the locks?
Front is locked. Rear is unlocked. Garage is open.
What is the meaning of life?
42
Any likelihood of this sort of thing being added?HS4, Insteon, Z-wave, USB-UIRT, Harmony Hubs, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, EZVIZ DB1 doorbell
Originally posted by Sgt. Shultz View PostFor those wishing to set up their own skill:
Endpoint: https://myhs.homeseer.com/process_echo/
Do you allow users to create an account or link to an existing account with you? Select 'Yes'
Authorization URL: https://myhs.homeseer.com/echo/user_app/
Privacy Policy URL: https://www.homeseer.com/privacy
You will need the vendorID from the 'Redirect URL' field for when you log in to link your skill to myHS.
Originally posted by waynehead99 View PostI can't answer the first part, but I do know that changing the name from Alexa... well you only have one option and that is Echo . Amazon controls that part and it hasn't changed since they created it, though there has been talks to adding more names. I suspect they picked Alexa from lots of research and figured its the least common word used daily, and easiest to have the device wake up on.
Personally I don't mind that part as much as "tell homeseer", i think they could tie into the light API... maybe?
Last time I checked (and it's been a few months). You can NOT tell Alexa to play "The Downeaster Alexa" by Billy Joel when the command word is Alexa. I have no idea why they parse it out after the first time that you say "Alexa". Perhaps because they think you are saying something like "Alexa, please play this song, Alexa". As it is it just replies "I can't find a song called "The Downeaster" by Billy Joel". Really saddens me cause I happen to really like that song. The only way I could get to it was to play the album and skip to it.
Like a bad monkey, I have never reported this to Amazon.
Sorry for the intrusion. Please go back to your regularly scheduled topic
Originally posted by DevinH View PostIn the Account Linking or Creation section, along with Authortization/Privacy Policy URL, it's required to enter Client Id - "Unique public string used to identify the client requesting for authentication". What should we put in there?
The clientID can be whatever you want it be..., we don't need it for our code.Wade
I wonder if the authorization URL is outdated. The directions say to use:
But it looks like the published skill is using:
https://myhs.homeseer.com/Echo/Echo_Default
I tried using that published skill URL for my own skill, and I when I click "Sign into your account" from the Alexa app, I do get a login form now, but when logging in I get the "Unable to link you skill, please try again later" message. Using the first authorization URL, I'd never even get that login form and instead get the error message immediately
