Go Back   HomeSeer Message Board > Irrigation Plug-ins > Irrigation Discussion > EZFlora Insteon Irrigation Controller Plug-in
EZFlora Insteon Irrigation Controller Plug-in Discussions of Adam Telford's EZFlora Insteon Irrigation Controller Plug-in
Old November 10th, 2016, 09:03 AM
thetaz01 thetaz01 is offline
Phantom Turn on?
SO I have my EZFlora for some time now..
I have NO scheduled turn on events, I have program 1 set for run times for two zones, but for right now trigger it manually...
However, last night, at 2am, I have several entries for the valves going on..
Any idea why this would have happened?
This has never happened before that I know of, I went back as far as I could in the logs and see no other entries like this
Nov-10 8:10:09 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 4:38:16 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 4:33:16 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 4:28:16 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 4:23:16 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 4:18:16 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 4:13:16 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 4:08:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 4:03:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:58:16 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:53:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:48:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:43:16 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:38:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:33:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:28:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:23:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:18:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:13:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:08:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 3:03:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 2:58:15 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 2:53:14 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 2:48:14 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 2:43:14 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Nov-10 2:38:14 AM EZFlora EZFlora 3D.D1.D9 valve 2 active
Old November 11th, 2016, 09:08 PM
hurry4it hurry4it is offline
The plugin only reports the status that is provided by the hardware. My guess is that the device just needs to be unplugged and plugged back in to reset it. Give it a try and let me know if it happens again. If it does, we will need to dig a bit deeper to find what is causing it to report this status.
Adam
Phantom Devices? madmax BLRadar (3P) 3 November 24th, 2012 09:14 AM
Phantom Flag Changes Mark S. JDS (Stargate, TimeCommander) 6 November 24th, 2011 12:29 AM
phantom system turn-on again... gfs mcsSprinklers 0 June 6th, 2009 08:00 PM
phantom all light on..still bjj HomeSeer General Discussion Area 3 May 18th, 2004 05:55 AM
phantom X10 signals byee Programming with HomeSeer 4 July 14th, 2002 12:29 PM
