About Sonos conditions for an event
    Do they work?
    When I select "Group Conditions" --> IF --> "Sonos Condition" I get a list box below called "Select Command" and the item it defaults to is "Please select"
    When I open this list, no matter what I select, it goes back automatically to "Please select"... so a condition cannot be chosen...
    I thought it could be a browser issue, have tried with Chrome, Safari and IE, all show the same behaviour...
    Anyone using Sonos conditions in group conditions for an event successfully?
    Sandro
    HS3 Pro Edition 3.0.0.548| Plug-Ins Enabled: Sonos 3.1.0.57, RFXCOM 30.0.0.45, X10 3.0.0.62, IPThermostat 3.4.5.0, Pushover 3P 0.0.0.54, Blue-Iris 3.1.3.33206, Z-Wave 3.0.10.0, BLML2HS 2.0.28.0, mcsMQTT 6.12.4.0, Insteon 3.0.7.19​​ | Win 7 32-bit | Intel Atom D2550 @ 1.86GHz 4GB RAM
    Originally posted by pyspilf View Post
    Do they work?
    Sandro
    The Sonos Conditions work fine within a group, but will not work in group conditions. Some plug-ins will work in group conditions and some won’t. I don’t know if the plug-in author has to do something different for conditions to work in group conditions. I don’t use group conditions, so I never noticed until I tested this morning. Easy Trigger Conditions do work in group conditions.
      Thanks a lot Randy. I tried conditions within a single event and it works fine, so I adjusted what I was going to do to work that way...
      Had no idea of what you mentioned about it possibly being something that needs to be developed specifically.
      Cheers!
      Sandro
