Anyone notice if this is a bit Hungary on CPU usage. Seems to go from about 2% to 79% when running !!!. Any suggestions ?
Find my iPhone plugin for HS3
Originally posted by jrhubott View PostI haven't noticed high cpu usage. I just checked my vm logs and don't see any spikes.
I will look into it but at the moment I don't know of anything that would cause a high cpu load.
Sent from my iPad using Tapatalk HD
Thanks. Would love to know what's causing it. On another note, if I delete a device that it's created (geocache location) will it re create it the next time the script runs as it has stopped updating or is there a way to reset it ?
Great plugin by the way, waited for ages for something like this !Steve
Originally posted by jrhubott View PostI've asked HS to add it to the downloader several times. I have sent them everything and submitted the form.
I have 3 other plugin's to add and I'm losing faith in getting them in the system.
Sorry everyone.
Jason
I have an event that when the kitchen motion sensor is triggered it refreshes the "find my device" .this then updates the geocache location to "home " , this should then disable cameras . This it does not do but the device status has changed to home. Do I need to setup to poll theLast edited by Stevieboy; November 8, 2014, 02:42 PM.Steve
Originally posted by macromark View PostJason - I get copied on plug-in submissions but I didn't see your's come in. When did you submit it? Also (FYI), Tyler is our point contact for updater maintenance. You can email him directly at "Tyler" at homeseer.com. And... you can also call us directly if you need immediate help with this. 603-471-2816. Tyler is at x107.
Guest
error message when running application
Hi there,
I believe I followed the instructions in terms of where to put the folder, but when I run the application file I get a weird error message and there is no xml config file created. See attachment for error message. Any ideas of what I can try would be appreciated
Adam
Mine too,
I has been a while since I did some testing, installed the latest version but my trial is expired :-(
Please let me know how to re-energize the plug-in, because it's a very promising one :-)
Thanks,Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
