HSTouch can't connect through myhs via vpn
    When I'm away from home HSTouch won't connect via myhs if my V PN software is running. I can however connect to my system through myhs on the same device using a browser. Any thoughts?
    Originally posted by rprade
    It might be a DNS issue from your VPN. Can you try to ping myhs when your VPN is active?
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      Well, like I said, I can access my system through the web interface with the VPN on. I'm not even sure how to ping anything from an Android device.
        With HSTouch using port 10200 that could it be that port may not be available on the VPN? You could try changing HSTouch to a known (think the option is in the HS settings if it is not an INI file setting) open port see if that connects.
          I'll try changing the port but I'm not sure if it will help because I'm using myhs. Honestly I have no idea.
            What client VPN software are you running on your Phone (Android?) and what server VPN software are you running at home?
            and
            What Internet browser are you running on your phone?
              Private Internet Access on the phone and at home.
                Does it work on your phone at home when you are connected to your wireless network?
                I would open a support ticket with Private Internet Access as the phone client should work fine with the service as it talks only via one port.
                You should not have to do anything on your end.
                  It works fine at home on W-Fi. Oddly EgiGeoZone doesn't communicate with HS when the VPN is on as well. I'm discussing that one with the developer. Backitude works just fine though. It's odd.
                    Not sure what telco you are using for your cell phone(s) there. Here in the Midwest T-Mobile is massaging the transport for their customers. I get messages from the T-Mobile Barracuda firewalls relating to my Homeseer 3 text messages here.
                    Odd for me as the source here is Homeseer and that never changes. I do not utilize myhomeseer dot com here.
                    That said I use IPSec VPN on a wireless client using the Mobile shared wireless and do not have issues with it. That is different though than using a VPN service.
