While I'm not at all sure it's actually a plugin issue, the plugin crashes within a few minutes of starting.
I'm running HS3 Linux, 3.0.0.425 with your plugin version 3.0.6.33. The most recent entry in the Insteon Error Report Log is:
The plugin is talking to an Insteon Hub:
INSTEON HUB2 Details
Hub2-V04-20140904
PLM Version:A3
Firmware:1015 Build Apr 2 2018 13:27:42
Insteon ID:34.1A.0F
This behavior started fairly recently, within just the last few weeks (and certainly after I upgraded to HS3 beta 425). I was previously running plugin version 30.6.32 when the problem first manifested; I updated to .33 just a few days ago to see if that would help. Another relatively recent change is that I think the Insteon Hub took an update a couple of weeks ago as well.
Any suggestions?
-M.
Insteon Plug-in Error Log Generated 4/24/2018 8:31:51 PM
-----------*Error Message*----------------
Error: Error in Hub.GetResponseCallback: Error: ConnectFailure (Connection timed out) -- Details System.Net.WebException: Error: Connect
Failure (Connection timed out) ---> System.Net.Sockets.SocketException: Connection timed out
at System.Net.Sockets.Socket.Connect (System.Net.EndPoint remoteEP) [0x000b6] in <67546f875ae44445b5aba5311d41f9dc>:0
at System.Net.WebConnection.Connect (System.Net.HttpWebRequest request) [0x0016d] in <67546f875ae44445b5aba5311d41f9dc>:0
--- End of inner exception stack trace ---
at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00058] in <67546f875ae44445b5aba5311d41f9dc>:0
at Insteon.Support.Hub.SocketPortClass.GetResponseCallback (System.IAsyncResult AsynchronousResult) [0x0000e] in <ba8300ec73074b6fbfc4
a9a387a06b37>:0 -- 4/24/2018 8:31:51 PM
--------*Initialization Log*--------------
4/24/2018 8:27:36 PM - Host System: 192.168.101.77 (elms-hs3-01) 3.0.0.425
4/24/2018 8:27:36 PM - Plugin HSPI_Insteon.exe version: 3.0.6.33
4/24/2018 8:27:36 PM - Insteon Support library (Insteon.dll) version: 1.0.6.33
4/24/2018 8:27:36 PM - RegisterCallback Completed
4/24/2018 8:27:36 PM - Enter InitIO
4/24/2018 8:27:36 PM - Enter InitPlugin
4/24/2018 8:27:36 PM - Global initialization of plug-in required, starting up.
4/24/2018 8:27:36 PM - Initializing Insteon hardware interface...
4/24/2018 8:27:36 PM - Initializing Interface...
4/24/2018 8:27:36 PM - In ProcessRawReceiveThread
4/24/2018 8:27:36 PM - In PLMBuffer_ProcessBufferThread
4/24/2018 8:27:36 PM - Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
4/24/2018 8:27:36 PM - Sending http://192.168.101.101:25105/1?XB=M=1
4/24/2018 8:27:36 PM - Sending http://192.168.101.101:25105/3?0260=I=3
4/24/2018 8:27:39 PM - ..did not receive a response from the Interface
4/24/2018 8:27:39 PM - ..Retry #1 required. Pausing 250ms for Interface to clear...
4/24/2018 8:27:40 PM - Sending http://192.168.101.101:25105/3?0260=I=3
4/24/2018 8:27:43 PM - ..did not receive a response from the Interface
4/24/2018 8:27:43 PM - ..Retry #2 required. Pausing 300ms for Interface to clear...
4/24/2018 8:27:43 PM - Sending http://192.168.101.101:25105/3?0260=I=3
4/24/2018 8:27:46 PM - ..did not receive a response from the Interface
4/24/2018 8:27:46 PM - Insteon hardware interface initialization failed.
4/24/2018 8:27:46 PM - Exit InitIO
-----------*Pre-Error Log*----------------
4/24/2018 8:27:46 PM - Could not contact Interface on 192.168.101.101:25105
4/24/2018 8:29:18 PM - The request timed out
--------*End Pre-Error Log*--------------
Hub2-V04-20140904
PLM Version:A3
Insteon ID:34.1A.0F
Any suggestions?
-M.
