Wim,
firstly let me say great work on the plugin so far, i am working to use Jowihue to bring across my 20 or so Zigbee devices. i have been using separate platforms like Hubitat etc.. but i want to have this working all in one box and minimise hubs etc.., so with that in mind i have installed deCONZ onto the same Windows machine as Homeseer, and have paired my devices.
so my Lightify bulbs work pretty well with the plugin, far more reliable than the Homeseer Zigbee plugin with the Lightify gateway.
but i have 4 Smartthings plug outlets. these also have current monitoring, however i am accepting that i will lose that functionality.
the device that Jowihue creates is a dimmable device, but the device itself cannot dim, and is reported by the API as an On/Off Light as you can see below.
that isn't the biggest issue however, the on/off status never updates it is always registering as off, but the on & off controls do actually turn on and off the outlet.
when the outlet is turned on the object returned is:
and when it is off it returns:
can you please assist and provide an update for jowihue to correctly handle this.
whilst here i have also paired smartthings door sensors and motion sensors, but other than a single temperature device these never update their values to deConz, has anyone else seen that behaviour and know how to resolve?
{ "etag": "d434bc806b5c1340d63782c481c30c46", "hascolor": false, "type": "On/Off light", "name": "Flowers", "modelid": "3200-Sgb", "swversion": "30065310", "uniqueid": "00:0d:6f:00:05:90:f6:e3-01", "manufacturername": "CentraLite", "ref": 0, "RefBri": 0, "RefHue": 0, "RefSat": 0, "RefCT": 0, "RecoverUnreachable": false, "SuspectAfterDeRegistration": false, "state": { "on": true, "alert": "none", "reachable": true } }
{ "etag": "2d766f91afc15fa05fcc2eb9c9c24e60", "hascolor": false, "type": "On/Off light", "name": "Flowers", "modelid": "3200-Sgb", "swversion": "30065310", "uniqueid": "00:0d:6f:00:05:90:f6:e3-01", "manufacturername": "CentraLite", "ref": 0, "RefBri": 0, "RefHue": 0, "RefSat": 0, "RefCT": 0, "RecoverUnreachable": false, "SuspectAfterDeRegistration": false, "state": { "on": false, "alert": "none", "reachable": true } }
