Homeseer Zee S2 Controller
    This controller can definitely control X10 but can it work with IFTTT and Alexa? If not, what minimum Homeseer hardware/software do I need to work with X10, IFTTT and Alexa? Thanks Much....Rick
    Yes it will work with X10, IFTTT and Alexa.
    The RPi3-HS3 device specifications are:
    • SoC: Broadcom BCM2837 (roughly 50% faster than the Pi 2)
    • CPU: 1.2 GHZ quad-core ARM Cortex A53 (ARMv8 Instruction Set)
    • GPU: Broadcom VideoCore IV @ 400 MHz.
    • Memory: 1 GB LPDDR2-900 SDRAM.
    • USB ports: 4.
    • Network: 10/100 MBPS Ethernet, 802.11n Wireless LAN, Bluetooth 4.0.
    It runs HS3 in Jessie using Mono.
      Thanks Pete,
      Do you know if the third part plugin for the Ocelots/Leopard 1 works with this hardware? Also do I need separate plugins (up to 5) to handle x10, ifttt and alexa or is this capability built in? I have pretty minimal requirements so this might be a good way to go for me and I am familiar with raspberry pi. Does this hardware also allow control from android or iphone and does it work with HSToich !!!!!!! Thanks again.....Rick
        Here tested my old Ocelot with the 3rd party Oclelot plug to work fine.
        It is here
        GTS CPUXA Ocelot Plug-in (3P)
        Alexa / HSTouch are built in now and not considered plugins.
        X10 works great. I have not tested IFTTT.
          Relating to the Zee-2 running Jessie. Ideally you want to get familiar with Linux commands in general to use it. It will be much easier to use having a bit of Linux knowledgebase.
          For using remote windows tools for Linux here I utilize:
          1 - putty
          2 - winscp
            Is ifttt supposed to work with zee s2 controller? I assume if it is and it works with other linux controllers, it should work on this one. Would I be correct in assuming this?
            What particular x10 hardware do you use to control x10 with the zee s2 controller.
            Do you know if the homeseer rcs thermostat works with this controller and linux?
            Also wondering if I can use android and ios phones to remotely control my devices with the zee s2 controller?
            Thanks again for all your help !!!!!! Rick
              yes
              CM11A direct and TW523 via Ocelot.
              I do not know.
              yes
                Thaks again !!!! I have some experience with the raspberry pi and linux but a bare minimum. I have several books on the raspberry pi so that is a good thing !!!!!! I will check with homeseer regarding ifttt on the zee s2 controller. Rick
                  Zee S2 Loses Time
                  I had a brand new Zee S2. It is on the Internet and there are no fire wall issues preventing it from keeping its clock in sync, but, it does not. Tonight was 35 minutes slow. If i go to the "run Linux Command window and run sudo sntp -s 24.56.178.140, voila, the time is then in sync. I'm not a programmer (anymore) and would like a plug in that can run a linux command or run a script that contains multiple commands. Can someone provide me a plug in that will run sudo sntp -s 24.56.178.140 4 time a day? Willing to pay for it.
                  Thanks in advance.
                    Install ntp on it by:
                    sudo apt-get install ntp
                    also
                    sudo apt-get install ntpdate
                    Your time should be fine afterwards.
                    Here on the original Zee S2 I installed a PiFace RTC which has a battery backed up clock.
                    You can add a time sync that occurs every day with cron.
                    sudo crontab -e
                    # Daily time update at 1:23AM
                    23 1 * * * ntpdate -s server1 [server2 ...]
                      You can create a script in the directories
                      /etc/cron.hourly/
                      /etc/cron.daily/
                      /etc/cron.weekly/
                      to run a command daily, weekly, monthly respectively.
                      However its possible you have a network configuration issue that could cause other issues down the road. Do you know if name services are working? If not, ntp won't run, nor will you be able to run the Homeseer updater.
                      To test, try the following two commands:
                      nslookup homeseer.com
                      (this is a lookup of the IP address of homeseer.com)
                      nslookup 24.56.178.140
                      (this is a reverse lookup of the hostname you've been using as your time server).
                      1st one should return something like this:
                      $ nslookup homeseer.com
                      Server:         192.168.1.1
                      Address:        192.168.1.1#53
                      Non-authoritative answer:
                      Address: 45.32.195.211
                      2nd one:
                      $ nslookup 24.56.178.140
                      Server:         192.168.1.1
                      140.178.56.24.in-addr.arpa      name = host-24-56-178-140.beyondbb.com.
                      Authoritative answers can be found from:
