FYI,
Donstephens and I bumped into an issue where we could not add users. That is, when you defined a user, and clicked to save the user, the save did not occur and you still ended up with zero users configured. In my case, my existing defined users disappeared, and likewise, I could not re-add them.
What appears to correct the problem is ensuring that ALL critical Microsoft updates are applied to the computer running HS. Likewise, we also installed any .Net related optional updates. Upon doing so, the problem was corrected.
What broke this, it is assumed that either a Microsoft update caused the problem, or less likely, a HS3 update caused the issue. Regardless, applying the Microsoft updates corrected the issue.
