Originally posted by gerenb
View Post
Jon00 Philips Hue Wi-Fi Lamp Controller for Homeseer 3 & Homeseer 4
Have a question about script execution Jon.
I have 17 hue lights on my network. I've got scripts that control color changes on the various lights, but a weird thing happens when one script executes after another.
For example, I have two hue lights that are set to ramp to different random colors, which works fine until another script executes to ramp a different set of hue lights to a different set of random colors.
The issue is that the first two lamps will suddenly stop changing colors and just remain at whatever color they were once the second color changing script executes for the other set of lamps.
I tried re-executing the first script to "restart" the first set of lamps, which works but then the second set of lamps stops its color changing cycle. It's seems I can only have one color changing script execution maintain its command at a time. Once another one executes it seems to pause the previous one. Is this normal?
Greg
Sent from my iPad using Tapatal
I got nixed on this idea
Wife says the bulbs are too small to look right in the high hats.
Hopefully Philips comes out with a bigger bulb...I want this!!!HS4Pro Win10 | Fire Tablet touchscreen client, Android Phones and Tablets | Jon00 | Smartthings | Philips Hue | Trane | Caseta | Nanoleaf | Ring | August | Evolve | Aladdin | Amazon Alexa/IFTT
Originally posted by gregtee View PostSure, I'd love to hear the details.
Greg
1) Copy the existing Jon00PhilipsHue client directory and contents to another directory.
2) With the second client, open up settings.txt and add the following to the bottom of the file:
clientno=1
Save the file.
3) In your Homeseer config folder, make a copy of Jon00PhilipsHue.ini and call it Jon00PhilipsHue1.ini in the same folder.
4) Run the second client and you should see it connect to Homeseer with client 1.
5) Use &hs.SaveVar "Jon00PH1","<command>") to operate commands using this client. &hs.SaveVar ("Jon00PH","<command>") will continue to work under the existing client.
I very much doubt they will ever want to make bulbs bigger - very old fashioned IMO.
Originally posted by jon00 View PostWhat wattage bulbs do you currently have in your high hats?
I very much doubt they will ever want to make bulbs bigger - very old fashioned IMO.HS4Pro Win10 | Fire Tablet touchscreen client, Android Phones and Tablets | Jon00 | Smartthings | Philips Hue | Trane | Caseta | Nanoleaf | Ring | August | Evolve | Aladdin | Amazon Alexa/IFTT
Originally posted by vanisher View PostI'm trying to install the plugin.. All files copied as they should..
BUT when i try to start the client it crashes.
Platform; Windows 7, 64bitsUbuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro ๐
Yes
hostadd=192.168.178.201
bridgeadd=192.168.178.19
Before you do anything else, please ensure that your lamps are operating correctly with your iPhone or iPad app. This ensures the lamps are correctly registered with the ZigBee IP Bridge.
This step gives me a crash:
Run the Jon00PhilipsHueHS3.exe client by clicking on the shortcut in your Windows startup folder.
